Towing package & brake controller question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman97, Jan 28, 2020.
  1. Jan 28, 2020 at 12:59 PM
    Tacoman97
    Tacoman97 [OP] Well-Known Member
    andrew
    new york
    2018 Calvary blue TRD PRO
    Question for you folks. If my truck has the towing package is there a need for a brake Controller? And can you elaborate your answers with why or why not? Thanks
  2. Jan 28, 2020 at 1:03 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    All depends on how big, and weight of trailer you plan on towing. You don't want the weight of trailer pushing you when you try to stop. I always set brake controller to engage trailer brakes to, have trailer help stop truck, vs truck stop trailer.
    Towing package includes hitch, wiring, trans cooler, and wiring for brake controller, But need adapter for controller.
  3. Jan 28, 2020 at 1:07 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    You'll need one if you're towing a trailer with electric brakes. The controller applies an electronic signal to determine how much braking is needed. If you have a surge brake, typically on boat trailers, you don't need the controller. Also most trailers rated less than 3500 lbs don't have brakes and so don't need a controller. A tow package adds a beefed up cooling system, electronics for trailer lights & power, greater amperage alternator, and hitch. A towing package is better with or without a controller.
    BSCowboy and na8rboy like this.
  4. Jan 28, 2020 at 1:13 PM
    Tacoman97
    andrew
    new york
    Ahh that’s kinda of what I was thinking. I knew all of what the tow package comes with. So simply said small/ light trailers don’t require the brake controls and generally the larger heaver ones do?
  5. Jan 28, 2020 at 1:13 PM
    na8rboy
    WI
    Great info, I should of added the electrics v. surge brakes.
  6. Jan 28, 2020 at 7:52 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    I have a tow package. What is my alternator pumping out compared to a non-tow package?
  7. Jan 28, 2020 at 7:55 PM
    knayrb
    Bryan
    Pure stock
    I might be wrong but I seem to recall a standard one puts out 90 amps and the tow package one is 120 amps.
  8. Jan 28, 2020 at 9:46 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
  9. Jan 28, 2020 at 10:47 PM
    ksJoe
    ksJoe Well-Known Member
    Joe
    Kansas
    2020 TRD Off-Road
    close
    small/light trailers do not have electric brakes, and so having a brake controller does absolutely nothing for those trailers.
    very large/heavy trailers will almost always have some type of brakes, often electric brakes. Electric trailer brakes won't work without the brake controller.
    If you're looking at a large u-haul trailer or similar, it will probably just have surge brakes as mentioned above. That's because u-haul rents to people without brake controllers, so they need brakes on the their trailers that work for everyone.
    So the question you need to answer is: will the trailer(s) you pull have electric brakes?
    If a trailer has electric brakes on it, it means the trailer is rated for enough weight that you would probably want/need the electric brakes. But if you're towing the trailer empty, you should be fine without the brake controller.
