towing package charging system
Discussion in 'Technical Chat' started by rnrcmpr, Apr 1, 2010.
  1. Apr 1, 2010 at 10:08 AM
    rnrcmpr
    rnrcmpr [OP] New Member
    05 4x4 DblCab Long bed Debadged
    How is the charging to the trailer battery regulated. Is it three staged?At the 7 pin connector I am getting 14.7v at idle. I do not want to cook my trailer batteries.
  2. Apr 5, 2010 at 4:14 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    It is regulated by the BCM. 14.7 sounds a little high, 14.4 is closer to normal. If your meter is accurate, I would say what you are reading is only present under no load. Hook up your tow rig battery, and it should drop to 14ish. If it reads any higher than 14.4 with the battery attached, try a different meter.
