Towing package did not provide connector plug for wiring brake controller
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 49creekers, Nov 23, 2015.
  1. Nov 23, 2015 at 10:40 PM
    49creekers
    49creekers [OP] Member
    2011 Tacoma Double Cab TRD
    Hi,
    I have 2011 TRD that came with towing package. Recently, I have noticed that my tacoma does not have service connector plug to wire brake controller for towing camping trailer. The owners' manual instruction book clearly tells the location of the service connector.
    I brought my tacoma to Toyota dealer where I purchased it before. The mechanic said they could not find the plug, but charged me $48. They could not do anything but let me pay. They said they are not sure whether the service connector is supposed to come with the towing package or not, so they did not give me the free service.
    My tacoma has towing package but unable to tow safely heavy trailers that use the builtin-brakes. Did my taco come from the factory with incomplete installation of towing package? Or all owners of 2011 Tacoma have to customize the vehicle to install brake controller by owners expense? Please someone give me advices about this issue.
    Thank you for your help in advance,
  2. Nov 24, 2015 at 6:17 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Mine came with a harness that would have to be installed, it was in the glove box.
    Medina33 and 49creekers[OP] like this.
  3. Nov 24, 2015 at 6:23 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    To be clear, there is a difference in getting the actual 'towing package' from the factory versus getting a tow hitch that is dealer installed and calling it a tow package.
  4. Nov 24, 2015 at 7:19 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Agreed, you may have a dealer installed tow hitch and add-on harness for brake lights. If the tow package was installed from Toyota there is usually the brake controller harness in the glove compartment. You still need to buy and install a trailer brake controller, it's just the pigtail for the brake controller that is included with the tow package.
    49creekers[OP] likes this.
  5. Nov 24, 2015 at 7:39 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do you have the factory 7 pin plug to the left of the receiver hitch? If no, then you do not have the factory tow package.
  6. Nov 24, 2015 at 10:01 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    49creekers, Your dealer sounds greedy to charge for something like that.
    My 2006 came with the "towing package" which consisted of the pink base radiator fan, group 27 battery, supposedly heavy duty alternator but no transmission cooler and only a four pin trailer connector. This was a dealer or port installed option. It was all I needed to tow my 18' center console.
  7. Nov 24, 2015 at 11:13 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    That pink rad fan base doesn't indicate anything. I'm a 4cyl with no tow package... I have a pink fan base too.
  8. Nov 24, 2015 at 11:22 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    49creekers[OP] and fla_sun like this.
  9. Nov 24, 2015 at 11:25 AM
    fla_sun
    thanks sr5vic, scratch that pink fan OP. :)
  10. Nov 24, 2015 at 10:29 PM
    49creekers
    Thank everyone for your comments. My 2011 tacoma has round 7 pin plug to the left of the receiver hitch. so my tacoma should have a towing package from the factory.
  11. Nov 25, 2015 at 4:30 AM
    taczilla
    Marc
    2016 RAM Rebel
    The connection is behind the driver's kick panel. I found mine buried under electrical tape on a wiring harness located above and to the left of the emergency brake. You should be able to find it and claim your $48 back from the stealership.
    Check the pic in Post #6 in the link above.
    ...and I used a Curt TriFlex and the model specific adapter harness.
    Controller:
    http://www.curtmfg.com/part/51140
    Harness:
    http://www.curtmfg.com/part/51362
    Inexpensive and works great.
  12. Nov 25, 2015 at 10:28 AM
    lickem66
    lickem66 Well-Known Member
    Portland, OR
    12 V6 DCSB 4x4 Sport 6MT
    Ride-Rites, OE tubes, Tri-Fold tonneau, extra bed D-rings, OE bedmat, center console organizer, rearview mirror bracket re-locate.
    My brake controller plug was jammed way up above the dead pedal. Had to reach up under the dash next to the kick panel until I could reach it and pull it down some. Major suckage!. Now it hangs just behind the kick panel.
  13. Nov 25, 2015 at 1:06 PM
    nd4spdbh
    SoCal
    if you dont have the trans cooler (auto trans) and no 7 pin... you do not have a factory toyota tow package.
    You have the factory tow package, the plug should be like stated in the left side kick panel... it will be there and it will be burried.
    This site will have exactly what you need, and has direct plug n play adapters, no need for the from toyota pig tail... plug one in of the adapter in the controller and the other into the harness and you are good to go.
  14. Nov 25, 2015 at 10:58 PM
    49creekers
  15. Nov 26, 2015 at 5:30 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    its hard to spot, its a white connector and like said above it is really buried behind a ball of wires. A friend had to help me find mine. when you buy a brake controller get one already setup for the Toyota Tacoma, worth it. 10 minute install!!!
  16. Nov 26, 2015 at 11:31 PM
    49creekers
    Dear StickShifty,
    Thank you for your comments. I keep it in my mind that the connector is buried far far behind a ball of wires.
    I will work for it in this weekend.
    Best
  17. Dec 27, 2015 at 1:55 PM
    49creekers
    Hi all who kindly gave comments to my post,
    I looked into the left behind the foot-brake. There was a ball of wires, but it was hard for me to recognize what looked like the connector. I brought my taco to my favorite garage where I usually ask oil change, tune-up, repairs etc. The mechanic had worked the same thing for Tundra, so he thought it was easy to install harness. However, even he had difficulty in finding the wire connector plug, but finally he made it.
    Because I brought TEKONSHA-brand brake controller and brake control harness (for Toyota), I was charged only the cost ($90) for his labor to install the harness and brake controller.
    Thanks again for everyone for your coomments!!!
  18. Dec 27, 2015 at 2:07 PM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    Tekonsha t3 is the best controller I've ever used. Glad to hear you found it. Mine was in a ball of electrical tape. The pucker meter was up pretty high when I was using the pocket knife in the factory harness to get to the plug! Go kick that stealership manager square in the balls and demand your money back. Tell him for a $100 you'll train his a-s-s certified loser on how to find wiring harness parts!
