Towing Package ID
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rnelson989, Sep 2, 2015.
  1. Sep 2, 2015 at 2:35 PM
    rnelson989
    rnelson989 [OP] Member
    2013 Pyrite Tacoma TRD 4DSB
    This is from the engine bay of my soon to be home 2013 V6 DCSB 4x4 TRD Off Road Tacoma. Was trying to verify that the truck has the towing package. I was told looking at the oil filter assembly would indicate if it had the oil cooling lines coming off the bottom. Is this correct and can someone verify if that's what I'm looking at.
  2. Sep 2, 2015 at 2:40 PM
    JPA2002
    JPA2002 Well-Known Member
    Roanoke, VA
    2021 DCSB TRD Pro
    Those are the oil cooling lines, so yes, it does have the factory towing package.
    Jon
    rnelson989[OP] likes this.
  3. Sep 2, 2015 at 2:41 PM
    rnelson989
    Thanks Jon
  4. Sep 2, 2015 at 3:30 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pretty sure ALL v6's have the engine oil cooler / subsequent lines.
    You need to look for the 7 pin harness, higher amp alternator, and extra small black radiator at the front of the radiator stack.
  5. Sep 2, 2015 at 3:53 PM
    JPA2002
    Roanoke, VA
    2021 DCSB TRD Pro
    Not all v6's came with the oil cooler. The oil cooler is part of the optional tow package, along with sway control programming, 7 pin trailer plug, trans cooler, larger battery, and high output alternator.
    Jon
  6. Sep 2, 2015 at 4:51 PM
    nd4spdbh
    SoCal
    Sure about that? I dont think i have ever seen a v6 without the oil cooler. Hell my moms 07 4 runner with the v6 doesnt have a tow package but its got an oil cooler (though the 4 runners could be different)
  7. Sep 2, 2015 at 4:52 PM
    Jacked05
    Jacked05 Well-Known Member
    Josh
    North Carolina
    18 TRD OR Premium MT
    +1
  8. Sep 2, 2015 at 4:57 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    My 05 didn't have it and also didn't have the factory tow package not all V6s come with those extra line im 110% sure
  9. Sep 3, 2015 at 7:42 AM
    nd4spdbh
    SoCal
    ah ok, i thought the oil cooler was standard. i know trans cooler isnt.
