towing package
Discussion in 'Towing' started by mkerros, Nov 16, 2008.
  1. Nov 16, 2008 at 11:30 PM
    mkerros
    mkerros [OP] Well-Known Member
    jacksonville florida
    06 d/cab long bed
    How do u know if your truck has a towing package i bought it used and wasnt really worried about it so i never asked them. the only reasone im wondering is because it has a hitch on the frame and the jack for the tralier lights.
  2. Nov 16, 2008 at 11:33 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    The dealer can check via the vin numbers & tell you what you have.
    Mine has a hitch & the wiring harness I installed. But I do not have the towing package.
  3. Nov 17, 2008 at 5:55 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    If it is the Factory Hitch the steel directly surrounding the hitch pin hole will be thicker than the rest of the receiver. The hitch will also be tied into the bumper by two bolts on either side of the ball mount hole.
    Since you have an automatic you will also have a trans cooler (Which will look like a smaller radiator mounted in front of the standard radiator of the truck).
    Lastly you can check the voltage of the top left pin, (the one in the roughly 10:30 position) on your plug. You should get 12-14 volts with the truck running.
  4. Nov 17, 2008 at 6:16 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    I believe you also get a larger alternator with the tow package. I have the tow package and unfortunately my fan blade clutch is pink. However, I am not sure if this is a valid way to tell.
  5. Nov 17, 2008 at 11:19 PM
    genxer36
    Sean
    Bethlehem,GA
    Just curious.
    How would the top left pin mean you have the towing package? Wouldn't that be the same either way?
  6. Nov 18, 2008 at 4:34 AM
    maverick491
    South Jersey
    The top left pin is the rv battery charging circuit. More often than not people who have added a hitch and a 7 round plug do not connect that pin as it really is a major pain in the ass to do aftermarket. While it can be done, it's just pretty involved, so it is a good final thing to check assuming that you have all of the other things I mentioned as well, as the other things can be added aftermarket easier.
  7. Nov 18, 2008 at 4:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have the factory towing package and my fan clutch is pink also.
    The factory tow packege on the Automatic trucks also got the transmission cooler (extra radiator looking device in the grill) and supplemental oil cooler (haven't really looked for this thing).
  8. Nov 20, 2008 at 12:09 AM
    genxer36
    Sean
    Bethlehem,GA
    But if they have the flat connector. that won't tell them anything. I have the flat 4-pin. I got the wiring harness from Toyota. Took me 5 minutes to install.Plug & play sorta speak
  9. Nov 20, 2008 at 4:59 AM
    maverick491
    South Jersey
    If they have the flat connector then they do not have the factory towing package. My answers are all based on the original quiestion which was how to tell if a truck purchased used had the factory tow package.
  10. Nov 26, 2008 at 4:50 PM
    2xtreme
    2xtreme Member
    Grand Forks, ND
    Blue TRD 4x4 longbed
    GM uses 2 or 3 digit codes listed in the glove box that correlates to all the installed options. Does anyone know if Toyota uses a code system like this?
    I had an issue a few years back where I was wrongly informed by the dealer after a Vin search. Later I discovered the codes in the glove box which were correct. Nearest I could figure, the sticker and options are done at the same time on the assembly line. Who knows, maybe the Vin said I was to get one package but they ran out of those parts, so the truck got an unplanned upgrade.
