Towing Package
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GaToyta18, Apr 19, 2019.
  1. Apr 19, 2019 at 1:53 PM
    GaToyta18
    GaToyta18 [OP] New Member
    i got a 2018 toyta base model. mine didnt come with towing package, just wondering where to get the right wiring harness/kit for it..
  2. Apr 19, 2019 at 2:02 PM
    BadCow
    BadCow Well-Known Member
    David
    2019 Tundra TRD PRO Super White
    If it was ME, I would have Toyota install that stuff. Not cheap, but done right.
    Garyji and GaToyta18[OP] like this.
  3. Apr 19, 2019 at 2:03 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Welcome :wave:. If you go to a local hitch installation place (not uhaul) they should have what you need. They can probably do it for you at a reasonable price too.
    GaToyta18[OP] likes this.
  4. Apr 19, 2019 at 2:04 PM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    Etrailer has what you need.
    Etrailer.com
    Frsh2df and GaToyta18[OP] like this.
  5. Apr 19, 2019 at 2:06 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Be mindful of how much you will be towing. The factory tow package comes with a trans cooler(automatics), so keep in mind you won't have that.
  6. Apr 19, 2019 at 2:07 PM
    JNG
    He's right. If your "base model" is a 4 cylinder SR, you are limited to 3500# gross trailer weight.
    GaToyta18[OP] and AxisCab like this.
  7. Apr 19, 2019 at 2:08 PM
    rblalliance
    08 TRD OR DCSB 4X4
    What he said
    Garyji, GaToyta18[OP] and shakerhood like this.
  8. Apr 20, 2019 at 1:07 PM
    GaToyta18
    thanks guys, just trying to weigh out my options. i was considering doing it myself but not exactly sure how do it.
  9. Apr 20, 2019 at 5:29 PM
    rblalliance
    08 TRD OR DCSB 4X4
    If you're comfortable working with electrical than you should be able to do it. If not, it shouldn't cost too much for a local hitch shop to do it. If you go that route you can have them install the7 and 4 pin connector that goes on the bumper. That will make it look like the OEM that comes with the tow package. Also, if your truck is an auto then you might want to consider adding a transmission oil cooler too. Like @JNG said, keep in mind that your max towing weight is 3500 lbs.
  10. Apr 20, 2019 at 5:33 PM
    JNG
    Go to Etrailer and check out the hitch options and wiring harness options. Etrailer has damn good how to videos as well. Watch them.
