Towing question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 709GADE, Jul 25, 2015.
  1. Jul 25, 2015 at 10:22 AM
    709GADE
    709GADE [OP] Well-Known Member
    '09 Toyota Tacoma 4X4 SR5 DC LB - Pyrite Mica
    Toyota aluminium side steps, Toyota door sill protectors Extang trifecta tonneau cover, U-Haul Class 3 hitch, Black Weathertech's, Front mudflaps trimmed 4", OEM Fog Lights, WeatherTech Bug Deflector, 13" Stubby antenna, TRD Skid Plate, ScanGaugeII, Carriage Works Billet Grille, Plasti Dipped overhead temp/compass console, LT265/75/16 Duratrac's LR C
    Towing a 3000lb travel trailer fully loaded, do I need LT tires or would P series be safe? Trailer has electric brakes and I have installed a brake controller and a weight distributing hitch. Don't plan on doing any real off-roading just maybe some gravel roads every once in awhile.
    I have a 2009 V6 4x4 SR5 DC LB and plan on upgrading from stock Dunflops?
    Thanks
  2. Jul 25, 2015 at 10:47 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    That means you should have a max weight of around 300 pounds on the tongue. "P" tires should be fine weight wise as long as you are not loading the bed of the truck. The problem would be the side to side movement causing heat and undue stress on the sidewalls. You will most likely wear them out faster if you do much pulling.. Here is an articled on what you are talking about. http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=70
  3. Jul 25, 2015 at 7:11 PM
    lickem66
    lickem66 Well-Known Member
    Portland, OR
    12 V6 DCSB 4x4 Sport 6MT
    Ride-Rites, OE tubes, Tri-Fold tonneau, extra bed D-rings, OE bedmat, center console organizer, rearview mirror bracket re-locate.
    no problem with P tire for towing that trailer. I pull ~5000 lb. travel trailer with the P's. I pump up the rears to 39-40 lbs. (cold) and that helps firm up the sidewalls some.
