Towing Question
Discussion in 'Towing' started by tacosport18, Aug 7, 2009.
  1. Aug 7, 2009 at 8:50 AM
    tacosport18
    tacosport18 [OP] Member
    Jeff
    Pittsburgh, PA
    09 TRD Sport DCSB
    I am new to this board and I recently purchased my first Tacoma (09 TRD Sport, DBL Cab SHort Bed w/ towing package) and I am getting ready to tow a 3000lb fishing boat with it. My question is should I use drive 4 or 3 when towing the boat? My father's was told by several mechinics to pull in drive 3 in his chevy silverado to avoid tranny problems down the road (he had OD, 3,2,1 for his automatic). As the tacoma has OD, 4, 3, 2, L, I wanted to know what everyone uses / recommends for towing. I was thinking towing in 3 or 4 for city driving, 4 on highways? Any feedback is greatly appreciated.
    Jeff
  2. Aug 7, 2009 at 8:52 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Try to keep it out of overdrive. I'd say go 4th gear, because I don't think you'll have any problems with it struggling.
  3. Aug 7, 2009 at 9:21 AM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    From what I understand the reason for keeping it in a lower gear for towing is to stop it constantly changing gear if you're in a hilly area or just on the border (speed-wise) of two gears. If it's in one gear and stays in there quite happily then I think you'll be ok.
  4. Aug 10, 2009 at 7:02 AM
    tacosport18
    Jeff
    Pittsburgh, PA
    09 TRD Sport DCSB
    Thanks for the input guys.
  5. Aug 10, 2009 at 7:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I tow a 3000# boat often, and I leave it in Drive, unless it starts to "hunt" between 4th and 5th on hills. Then, I just drop it in 4th.
  6. Aug 10, 2009 at 7:14 AM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    We tow our sailboat in D...its not that much prob 1000lbs but we have overdrive i thought 4 was OD
  7. Aug 10, 2009 at 7:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "Overdrive" is a gear ratio that is lower than 1 to 1, for example a .85 to 1. I belive out 4th gear in the autos is a 1 to 1 ratio
  8. Aug 10, 2009 at 7:21 AM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    so do we have an overdrive button or something?...when im driving and i drop it to 4 it seems like overdrive in other cars/trucks
  9. Aug 10, 2009 at 7:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    An "Over drive" lowers the rpm's. 5th gear is the "Over drive".
  10. Aug 10, 2009 at 7:24 AM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    Oh, not really good with all these terms...never mind then...
