Towing Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jagman276, Jul 16, 2019.
  1. Jul 16, 2019 at 3:08 PM
    jagman276
    jagman276 [OP] New Member
    bob
    2015 Tacoma Access Cab
    Hey Guys.. Thanks in advance for your response. I recently purchased a 2015 Tacoma Access Cab with the little 4 cylinder engine. I have a small 16 foot aluminum fishing boat that I am planning on towing with it. I did a test tow today and on regular roads, it did fine. But on the expressway I felt like I was under powered at the 70 mph space. So my question is this: If I have a 4 speed, I know I can drop it into 3rd to help with speed on hills and such. But how do I know if I have a 4 or 5 speed? I have gone through a few starts and stops counting the gear shift points and it seems like it's a 5 speed, but I can't really be sure because my shift knob indicator goes from 1,2,3, D. I can only drop back into 3rd gear.. Cornfused and Cornflicted because after monitoring the shift points it seems like when it does drop into 4th, 5th comes very shortly after and the rpms drop even more.. Any help would be greatly appreciated and thanks in advance.
  2. Jul 16, 2019 at 3:26 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    It’s a 4 speed and if you want to optimize your power shift it like a manual when towing. Also keep it out of D. I’ve towed over 4000lbs on the highways with my 4cyl and it did fine.
    Nessmuk likes this.
  3. Jul 16, 2019 at 3:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Jul 16, 2019 at 5:08 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Torque converter locking up and unlocking in 4th can feel like another shift - that's what you are feeling.
