Towing RPMs???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WoodsGhost, Jul 14, 2021.
  1. Jul 14, 2021 at 1:01 PM
    WoodsGhost
    WoodsGhost [OP] Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Got a travel trailer awhile back. Weight is around 3000lb loaded.
    My question is, what is a suitable RPM to be in while going up hills? Is 4-5000rpm ok for these trucks while going up long hills?
  2. Jul 14, 2021 at 1:07 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    if you are Auto Transmission always use S mode - when it starts the monkey shift (up and down and up and down) lock it down one notch. Nothing wrong with 4K rpm pulling a hill and a little higher for short durations.
    Junkhead and WoodsGhost[OP] like this.
  3. Jul 14, 2021 at 1:14 PM
    WoodsGhost
    PA
    I always use S4 and ECT.
    Good advice thank you
    JustJon likes this.
  4. Jul 14, 2021 at 3:50 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'll be fine,,, actually that's where the be V6 makes it's power and runs best, it's just different from what most of us have been used to.
  5. Jul 14, 2021 at 4:16 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Let it rev.. vtec yo!
    Loan Wolve and WoodsGhost[OP] like this.
  6. Jul 14, 2021 at 4:31 PM
    WoodsGhost
    PA
    Ive always felt “Ahhh its above 3k, shes gunna blow!”with all the vehicles I’ve had idk why
    Loan Wolve likes this.
  7. Jul 14, 2021 at 4:34 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Absolutely in S4/S3/S2 & GO!
  8. Jul 14, 2021 at 4:54 PM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    S4, ECT on, I tow a 3500#TT up hills, 3500 RPM + and my Scan gauge never shows abnormal temps.
    The racket is annoying but the truck can handle it.
  9. Jul 14, 2021 at 4:56 PM
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    That’s the old V8 mentality. I manage a fleet of machines all with small diesel motors. All of the machines run at full throttle 8 hours a day and they last what would equate to 500,000 miles. When they are up in the high revs their lubrication and cooling systems are all running at max.
    I’m not concerned about the higher rpms at all.
  10. Jul 14, 2021 at 5:05 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    It's got a 6k rpm redline. It has peak HP @ 6k RPM. It also has a peak torque @ 4600 RPM.
    It will pull untill 6k and not break a sweat.
  11. Jul 15, 2021 at 3:05 AM
    WoodsGhost
    PA
    :thumbsup:Thank you everyone for the replys. Its very enlightening to here this. After this, I will enjoy towing alittle more knowing that the truck will be ok.
  12. Jul 15, 2021 at 5:00 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    It is ok for any motor to rev a bit when it needs to. If you are trying to go up a hill at the same pace as level ground then it will shift down and rev up. That's normal.
    When pulling loads with my truck, I tend to hold the pedal and as I go up a hill, I will lose some speed but It will not down shift. I may start a hill at 65 mph but by the time I crest it, I will be at 50 mph and I'm fine with that. I put my truck in 4th and it stays in that gear most all the time. Sometimes when touring with our RV (3500 lbs loaded) my GF likes to drive and that's fine and when she goes up hills, she puts her foot into it until it drops into 3rd. So now instead of the low drone of 2500 rpm we are slammed into the 3500 , she's going to blow rpm. Not sure if you're aware but the 4.0 is not a graceful revving engine. So I ask her, ever so gently, did we really need to go up that hill so fast? lol
  13. Jul 15, 2021 at 7:34 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Hills here ain't huge here, but have towed my 2k lb boat, and gear using ECT S5....usually the rpm don't exceed 3k at 50 mph.
    Junkhead likes this.
  14. Jul 15, 2021 at 7:50 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Using s4 on the guest seems a bit extreme to me. The whining engine would annoy me. I just put mine in drive, hit ETC, and let it do it’s job.
  15. Jul 15, 2021 at 7:54 AM
    eurowner
    eurowner Duke Sky
    Scoty
    When towing? Start saving money for a new transmission.
    VB25 likes this.
  16. Jul 15, 2021 at 7:55 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Let ‘Er Rip!
  17. Jul 15, 2021 at 7:55 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Agreed here. It took a bit of getting used to at first, but these engines make their power around 3500 RPM. In the old days of the 3 speed transmissions the truck wouldn't ever have to shift but you'd be pretty much winding it out at 3500 RPM. Luckily today's trucks are geared a touch different, especially with direct injection demanding more RPM.
  18. Jul 15, 2021 at 10:24 AM
    WoodsGhost
    PA
    :yes:
    eurowner[QUOTED] likes this.
  19. Jul 16, 2021 at 5:42 AM
    zoo truck
    None
    Same here. While i wouldn't use drive for anything over 1k lbs. Found S5 very good for that'd a bit more.
