Towing small trailer cross country with 4banger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe O., Dec 7, 2020.
  1. Dec 7, 2020 at 7:45 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Since nobody’s mentioned it yet I will.... anybody else missing those days when you could fit everything you owned in a 5x8?
  2. Dec 7, 2020 at 7:49 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Take it slow and check on things the first few hundred miles. Once you know things are settled and safe. Travel at a safe speed for your comfort and the traffic around you, knowing that you can’t accelerate like an empty truck, braking shouldn’t be too different.
    -edit
    here’s how I did it 5 years ago. https://www.tacomaworld.com/threads/enclosed-trailer-buy.376994/page-2
    PintSize and Joe O.[OP] like this.
  3. Dec 7, 2020 at 7:51 PM
    Toyko Joe
    I just moved from west coast to east and I doubled the amount of stuff I had to move in two years! I’ll blame it on the kids.
    Joe O.[OP] likes this.
  4. Dec 7, 2020 at 8:53 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Go slow... enjoy the sights .. you will be fine.
  5. Dec 7, 2020 at 9:23 PM
    Joe O.
    Joe O. [OP] Member
    Joe
    2020 access cab 6 foot bed Tacoma
    Should I really drive in ECT mode the whole time? Seems like it would max out my RPM going up those long rolling hills. In fact, I usually avoid cruise control for the same reason. It always sends me to 4k-5k rpm when it’s not necessary
  6. Dec 8, 2020 at 1:24 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Per the manual every time you tow you should he using ECT and S4.
    Chew likes this.
  7. Dec 8, 2020 at 2:43 AM
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    However some people just shouldn't tow period.
    To OP: don't know if the 4cyl's have sport mode or not, but if you do, use it to keep rpms higher going through mountains. Then you won't shift every 5 seconds like my 6cyl likes to.
  8. Dec 8, 2020 at 6:04 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Just expect a very big difference at higher elevations. Don't worry when it happens, your truck isn't broken and the relative "zip" will come back as you head back down closer to sea level.
    I would grab the 2LM mod, it really helps with this.
  9. Dec 8, 2020 at 6:25 AM
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Yes, though it seems a prerequisite for agreeing is that your name is Joe: upload_2020-12-8_9-24-48.jpg
    Lotta Joe's on TW.
  10. Dec 8, 2020 at 3:31 PM
    RushT
    North Texas
    Lol for sure.
  11. Dec 9, 2020 at 6:48 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    you will be fine, the rating is roughly 6400 pounds on the tow package from the dealer. i towed about 4000 pounds a couple years back on flat surface for about 350 miles but my tongue weight was off and the truck was light in the front for steering, but you should be good...will cut your mpg..
  12. Dec 14, 2020 at 3:36 PM
    Artjr
    Artjr Well-Known Member
    Art
    2017 SR 2.7
    Cruise Keyless entry Apple Carplay
    Did you make it?
  13. Dec 14, 2020 at 4:08 PM
    Joe O.
    Joe O. [OP] Member
    Joe
    I’m not going until next month, but I just reserved my UHaul. Taking 84 from Portland to Utah, then 80 through Wyoming/Nebraska/Iowa to Chicago for awhile!
    shakerhood and Artjr[QUOTED] like this.
  14. Dec 14, 2020 at 4:09 PM
    TacoDDS
    TacoDDS Well-Known Member
    2017 SR5
    Does the tow package entail more than just the hitch? Tranny coolers and what not? Can these be added
  15. Dec 14, 2020 at 4:10 PM
    #35
    Artjr
    Art
    2017 SR 2.7
    Drive safe and let us know how it was.
    LilTexan22 and Joe O.[OP] like this.
  16. Dec 14, 2020 at 4:16 PM
    #36
    Joe O.
    Joe O. [OP] Member
    Joe
    all I have is the Uhaul brand hitch which is rated for like 8,000 lbs, but I’ve done nothing to my engine and don’t have a trans cooler. Is it worth it if I only plan on occasional (<once a year) towing?
  17. Dec 14, 2020 at 4:19 PM
    #37
    Artjr
    Art
    2017 SR 2.7
    You should at least get a OBD2 Bluetooth scanner so you can keep a eye on your transmission temperature
    boston23 likes this.
  18. Dec 14, 2020 at 4:22 PM
    #38
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    God yes. I'm not one of those people that needs a storage unit or anything yet, but do I really need 15 fishing rods (yes), duplicate power tools (yes), and enough camping gear to survive a russian winter (also yes)?
    I for sure remember when everything I owned fit in a college dorm room. Definitely miss it sometimes.
  19. Dec 14, 2020 at 4:26 PM
    #39
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I over heated the trans in my jeep, fully loaded it with all my stuff and moved cross country. Engine light came on in Utah. Now im in a taco...
    Consider installing a transmission cooler, i hear the 2020’s don’t have them
  20. Dec 14, 2020 at 4:29 PM
    #40
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I remember going up that first hill; I was so scared you couldn’t have hammered a finishing nail into my ass. Now, I just laugh at it. I’d switch the rear diff oil over to synthetic, as well and good luck!
    shakerhood likes this.
