Towing teardrop and 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2021SR5V64WD, Jul 10, 2023.
  1. Jul 10, 2023 at 10:33 PM
    2021SR5V64WD
    2021SR5V64WD [OP] Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    OK so here's a scenario that popped into my pea-brain while breaking bread at dinner.
    I'm going to case a HipCamp location of 800 acres in S.W. Arizona next week, actually
    going to Glamp at the site and hopefully get some milky-way shots.
    Anyway the location advises 4WD vehicles are best suited for the area.
    The 800 acres has several 'camp' sites on it and I thought about taking the teardrop down
    there when the weather cools.... current temps are close to 115-120 now... lethal.
    So, when normally towing I'm using ECT and S4 on paved roads.
    But what-say-ye should I turn off onto one of these dirt-roads and drive 8-10 miles that
    could use 4WD traction-action. Do I turn off ECT and S4 and only run in 4WD or do I use
    a combo since I'm towing a teardrop ( 1000 pounds plus bed-gear ).
  2. Jul 10, 2023 at 10:38 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Any combination will be fine. You won’t be going fast enough towing on dirt roads to get torque converter lock in 4th anyways.
  3. Jul 10, 2023 at 10:59 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    ^I agree
    Make use of 4lo to crawl your trailer over the rough bits (expected since they are calling for 4wd, no? - unless is is a sort of 'dress code' thing.). I prefer low drama to the spinning wheels, rocks flying and sh*t bouncing everywhere that seems so popular in some parts...
    You'll keep the fine china and champagne flutes in one piece to sip while staring at the sky...
  4. Jul 11, 2023 at 12:09 AM
    2021SR5V64WD
    Yea I'm interested in what the actual terrain is, this first pass will be without the teardrop. The directions to the location warns specifically about
    not turning down this road and not turning down that road so I suppose it could be a good exercise for 4WD use. It'll give me an idea how to handle
    a future trip with the teardrop as well. I suppose I'll just go 4WD and ECT and standard Drive in that case. If I have to use 4Lo I'd think taking it out
    of ECT would be the way to go.
