Towing the Prius across the country.
Discussion in 'Towing' started by bowzerdoo77, Apr 7, 2013.
  1. Apr 7, 2013 at 4:19 PM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I am about to use a car dolly and tow my prius from North Carolina to Utah, My question is should I have anything speical done to my truck besides the obvious such as checking the ATF and having it flushed before I head out the door. has anyone used the Tacoma to tow a car before? and will it put miles on the prius as well?
  2. Apr 13, 2013 at 2:21 PM
    nathan3306
    nathan3306 Well-Known Member
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    Should be good to go. Do the basic maintenance on the truck and it will be fine.
    Mile on the prius... doubt it as it is front wheel drive and those will be on the trailer.
    I would highly recommend an actual car trailer. Those car dollies are a pain on the ass and I hate towing with them.
  3. Apr 14, 2013 at 9:57 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    No car dolly would be best.
    Brett
  4. Apr 15, 2013 at 4:15 AM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Yea I've used both and for little cars Dolly's work the best!
  5. Apr 15, 2013 at 6:42 AM
    nathan3306
    Nathan
    Charleston AFB, SC
    2012 SR5 DC 4X4
    Not sure how a car dolly is better or how far you guys have driven with them but I did not like them. Sure its and easier tow because there is less weight but Iturning with them and traveling across country with them was a real pain.
    Tow with what you want. Either will be fine but my vote still stands for an actual trailer.
    If you are renting a truck then I would use the rental to tow the car. Less wear and tear on your truck.
