Towing tire PSI?
Discussion in 'Towing' started by Pruby18, Dec 15, 2019.
  1. Dec 15, 2019 at 11:30 AM
    Pruby18
    Pruby18 [OP] Well-Known Member
    2019 DCSB OR 4X4
    About to tow my motorcycle and trailer about 1k miles. Should be around 2k pounds with all my stuff. Should I increase the tire pressure? I have the stock wheels and tires at about 32.
  2. Dec 15, 2019 at 1:54 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    No. That’s a light load just tow as it is. There’s been other conversations on TW about the same thing. All I can say is I’ve towed travel trailers, trailer trailers and boats trailers with various trucks and have never adjusted the air pressure in my vehicle tires due to what I was towing. I’ve not experienced a single problem with my vehicle tires while towing. The only thing i do is make sure my trailer tires are at max pressure as stated on the sidewalls .
  3. Dec 15, 2019 at 1:55 PM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    The only air pressure you should be adjusting when towing is your helper bags.
  4. Dec 18, 2019 at 7:55 AM
    96carboard
    96carboard Well-Known Member
    If you put that entire load ON THE TRUCK, then you'd want to increase the tire pressure a bit.
    But since its all on a trailer, leave the tire pressure alone.
