Towing to Alaska
Discussion in 'Towing' started by Travelintaco87, Apr 17, 2021.
  1. Apr 17, 2021 at 10:44 AM
    Travelintaco87
    Travelintaco87 [OP] New Member
    2019 Tacoma TRD off road
    Starting new job in Alaska and looking to pull my travel trailer. Specs for the camper are: GVWR 3,518 lbs.
    Hitch Weight 298 lbs
    I towed it from Salt Lake to Wyoming but I am being overly cautious about towing it to Alaska. Thoughts?! Should I get a bigger truck?
  2. Apr 17, 2021 at 12:25 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    What will your trailer weigh when fully loaded for the trip? How much weight will you be hauling in your truck with passengers and stuff in the bed if the truck?
  3. Apr 17, 2021 at 12:28 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It’ll be fun (they said). Good luck with the new job!
  4. Apr 17, 2021 at 5:59 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Is the road paved all the way? Ignorance asking.
  5. Apr 18, 2021 at 8:20 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just about. Minor sections of dirt/gravel that vary each year for maintenance.
    Travelintaco87[OP] likes this.
  6. Apr 18, 2021 at 8:21 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    You'll be fine. Make sure the truck and trailer are in good shape and have plenty of extra gas, you'll most likely need it with the abysmal fuel economy you'll get.
  7. Apr 20, 2021 at 8:09 PM
    Travelintaco87
    The dry weight is 2,731 I have some ski gear. Camping gear and 2 duffel bags of clothes. I've made the drive before but just not yowing anything.
  8. Apr 20, 2021 at 8:11 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    You’ll be fine
  9. Apr 20, 2021 at 8:13 PM
    Bishop84
    Bishop84 Well-Known Member
    Make sure to have documents ready proving your work and purpose. BC is doing check stops for tourists invading.
