Towing Travel Trailer with 2016 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by flying_snowman, Jun 17, 2016.
  1. Jan 3, 2020 at 11:46 AM
    #101
    arnette64
    arnette64 Well-Known Member
    Amos, QC (Canada)
    2016 Inferno TRD Sport Double Cab 4X4
    '16 Inferno TRD sport DC
    32 ft 2005 R-VISION TRAIL CRUISER Trail lite : dry weight 4289 lbs, about 5200 lbs when load with all the camping gears, bicycle, etc/full propane gas tanks, etc... empty water tank
    gas mileage = horrible ;P , 22-24 L/100km (i'm Canadian, km here sorry)
  2. Jan 3, 2020 at 1:19 PM
    #102
    tacojpklx
    tacojpklx Well-Known Member
    eric
    michigan
    '10 AC OR, Magnetic Gray, 6spd
    toytec lift (eibach, bilstein 5100 at 0, Recall springs +Sumo Springs) seat covers, tint, weathertecs, shrokwork sliders, brute force rear bumper, in bed hi lift.
    I question how many scale their rig? I have. I found out it is ez to run out of payload on the truck. This is on my access cab with me and my gf towing a 2500# wet epro 14fk single axle. The quad cabs have even less payload. My tongue is 380#. People talking 600# of tongue...the truck will be overgross with humans and stuff inside.
  3. Jan 3, 2020 at 2:10 PM
    #103
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    My friend has a lifted Tundra and get 28 L/100km pulling his boat which is less weight then you are pulling.
    arnette64[QUOTED] likes this.
  4. Jan 7, 2020 at 12:19 PM
    #104
    Super Guest
    Super Guest Active Member
    Adam
    2019 Tacoma TRD Sport
    How does the truck feel when pulling a trailer that size? Any issues with stability or wind?
  5. Jan 7, 2020 at 6:27 PM
    #105
    chabunga
    chabunga Active Member
    Emmett
    Madison, WI
    2018 Quicksand Tacoma TRD Off Road
    It's been interesting reading these posts about Tacos and how much you can pull. Opinions seem all over the place. We have a 25ft Jayco, dry is about 4200, with gear but not clothes or food it weighed in at 4800 lbs. When I add the rest it should still be well under the max. I have a Equal-i-zer WDH and I have a brake controller. Been on a couple of trips around 250 miles. The Taco is a 2018 TRD Off-Road with the towing package, auto trans. It seems to pull best around 60 mph, with ECT and 4th gear. I do feel it when semi's go by. We're going from Wisconsin to AZ. Some might say I'm crazy, some will just say "have a nice trip". I do have a question for others like me. How far do you pull in a average day?
  6. Jan 7, 2020 at 8:38 PM
    #106
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I don't pull regularly, but my first pull was about 335 miles. I think it took me about 6.5 hours, including 3 stops for gas and 2 resets of the weight bars on the WDH when they popped when turning tight (coincided with gas stops both times). I probably could have done another 2hrs or 100 miles before fatigue set in. I definitely was aware I'd been driving at the end of those 6.5 hours. But this was my first real haul, I was doing it solo, and it was in the hill country. So maybe some more relaxed highways would have netted me more miles. My fuelly average was 18.5mpg at ~28k miles before that trip. Now I'm down to 17.7 mpg avg.
    chabunga[QUOTED] likes this.
  7. Jan 7, 2020 at 9:16 PM
    #107
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    At what weight do the WDH, sway bars, and a brake controller become necessary?
  8. Jan 8, 2020 at 2:32 AM
    #108
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    If your trailer has brakes, it's in your best interest to use them, so you need a controller. That sounds rude but is not meant to be. Wdh and sway bars involve a lot of other variables but anything that can legitimately make your rig safer and more controllable is a good thing.
    arnette64 likes this.
  9. Jan 8, 2020 at 3:42 AM
    #109
    RushT
    North Texas
    I guess a fair place to start is Toyota’s recommendation. I think they have an unbraked towing limit in the manual. I don’t recall it though.
    As above, it’ll help at any weight, but more so as weight goes up.
  10. Jan 8, 2020 at 6:31 AM
    #110
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Different people have different comfort levels so it is hard to say when WDH, sway, etc. is needed...
    If the trailer is causing any significant squat, especially if it is starting to take load off the front wheels and thus affecting your ability to steer, then you should really have it.
    Towing a camper, unless it is really small, anti-sway is a good thing. A camper is a big flat brick going through the air and can catch a huge amount of wind and turbulence from semis and other large passing vehicles, causing sway to start.
    As far as brake controllers, you might want to check with your state laws. Some have certain weight limits where it is required, some require you to use them if the trailer is equipped with them.
  11. Jan 8, 2020 at 9:00 AM
    #111
    chabunga
    Emmett
    Madison, WI
    In Wisconsin electric brakes are required on any trailer above a certain weight. It’s either 3000 or 3500 lbs. Can’t remember which it was.
  12. May 18, 2020 at 12:39 PM
    #112
    4x4erik
    4x4erik Well-Known Member
    Erik
    2018 White Tacoma TRD Sport Double Cab 4x4
    -Currently Leveled (Bought that way) -265/70r17 Nitto Ridge Grapplers -OEM Sport Wheels with 1.25" wheel Spacers -Many Changes Coming soon! See my old Jeep and now my Tacoma build @4x4erik
    Completely new to towing travel trailers (have towed trailers, goosenecks, and flatbeds with equipment with a dually in the past)
    IMG_20200517_192636.jpg I have a 2018 Tacoma TRD Sport Double Cab 4x4
    What do you all think about something like this for the Tacoma?
    https://www.rvtrader.com/listing/2019-Travel-Lite-Falcon-F-24RBK-5012331562
    I've been looking for something light with a low tongue weight. The Travel Lite is the lightest I've found. I need something that will comfortably sleep my wife, and my two kids, and hopefully one more when we expand again . I really want a tow hauler but a toy hauler in our towable weight that will sleep us all seems unrealistic... Except for this?
    https://rv.campingworld.com/rvdetai...r-wildwood-fsx-210rt-toyhauler-20k-SRM1744821
    Does anyone have any advice or input? Thank you for your time. Pic is for attention. (My truck)
  13. May 18, 2020 at 12:53 PM
    #113
    RushT
    North Texas
    My thoughts are that it's going to be on the easier side to tow with regards to it's actual weight. It has a pretty sloped front end so wind resistance will be lower compared to others. Double axle helps too; usually there's a lower tongue weight when you add the second axle. But 4200lbs may equate to near 5000lbs by the time you load it up. If you're geared up correctly with a good WDH and brake controller, and your expectations are moderate, I'd say you're okay.
    If you're towing 800+ miles monthly, it may wear on you. If you're towing 250 miles 4-5 times a year then that's a different story. You just have to realize that the 3rd gen makes it's power above 3500rpm, so you'll need to be ablate accept hearing the rpm's run when you're at speed or in the hills.
    Other's have probably towed similar trailers, so hopefully you'll get some more direct feedback.
    4x4erik[QUOTED] likes this.
  14. May 18, 2020 at 1:20 PM
    #114
    4x4erik
    Erik
    Thanks for the response.
    I think we are pretty much thinking the same things.
    I'd assume we will fit the second description much better, only probably 10 times a year and less than 150 miles for the majority of the trips. The 3rd generation power band is pretty odd to me, but I have to say I enjoy driving the truck alot. We will see how it goes. I'm excited, I am currently in Germany (Stationed here) and will be going to Texas for our next assignment. Shouldn't be too bad, being that there are not many hills
  15. May 18, 2020 at 5:47 PM
    #115
    RushT
    North Texas
    I’m in Texas myself. Took a 3750lb loaded trailer to the hill country. That trailer was not kind for wind resistance. 3rd gear rocked in the hills as long as you were ok with 4500-5000 rpm and 10mpg. :). I also was running 65-70mph.
    Truck handled it well, given my earlier caveats.
    4x4erik[QUOTED] and deusxanime like this.
  16. May 18, 2020 at 7:40 PM
    #116
    Gcsteve
    Gcsteve Well-Known Member
    long island
    2015 Red sold, 2017 Inferno Sport Traded for a Honda w/ payload #1500
    20,000 miles with this set up. Trailer is 19 ft about 3700 loaded. Over 400lbs hitch weight. It is small and light and I am always over payload by hundreds of pounds. If you keep anything besides a driver and passenger, I'm 160 my wife 120lbs, you are over. If your dealer told you your hitch is 400 lbs it is probably 550. Dealers no very little and just want to sell. With that said my truck does fine. Aal with sumos, no wdh and I get about 9 mpg. In Texas open roads with some wind I have seen 6 or 7. That was nerve racking watching gas go down fast. If you keep it small the wdh isn't necessary it also take around 70 lbs of payload.
