Towing vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hipster dufus, Oct 6, 2020.
  1. Oct 6, 2020 at 3:59 AM
    hipster dufus
    hipster dufus [OP] Active Member
    2020tacoma DC
    Got my 500 miles on my new rig, sr5 v6. Towed my boat, approx 1700#, yesterday. Around 70-75 mph i got a vibration thru truck. Felt it in seats. Slowed down and it went away. Any ideas on cause? Did use ect mode to tow. Is this the preffered method? Any other help greatly appreciated. Thanks
  2. Oct 6, 2020 at 4:43 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    My guess is the tongue of the trailer is not heavy enough and the trailer is vibrating on the ball on the truck hitch.
  3. Oct 6, 2020 at 5:06 AM
    hipster dufus
    2020tacoma DC
    might try to lower hitch ball, seems a little high as opposed to level
  4. Oct 6, 2020 at 5:42 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When i setup my tow height for the 2k lb boat i tow, i needed to raise my receiver ball 2'' higher with the taco vs the tundra i had to make the trailer level. I don't tow speeds higher than 70 mph. Haven't noticed any vibration in my sr5 access cab...truck tows and rides better with a load back there....wish it rode that good empty.
  5. Oct 6, 2020 at 7:29 AM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    Definitely continue to use ECT while towing. Could be tires causing the vibration. My utility trailer had vibrations above about 55 mph until I got radial tires. Night and day difference. No shakes or vibrations anymore, regardless of speed.
  6. Oct 6, 2020 at 7:50 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    If it's only doing it with the tow, then it's in the trailer/hitch set-up.
    G.
  7. Oct 6, 2020 at 10:09 AM
    zoo truck
    None
    How did the trailer/boat tow previously to the new tacoma?
  8. Oct 6, 2020 at 11:42 AM
    hipster dufus
    2020tacoma DC
    used my 2015 nissan frontier before bambi wrecked it. no issues towing at all. i think i need to lower my hitch but i couldnt find a straight draw bar today. if im not level it isnt off by much
  9. Oct 15, 2020 at 10:08 AM
    hipster dufus
    2020tacoma DC
    Had a broken bunk on the trailer. Was just an 8' 2x4 w a plastic cover. Replaced w a 2x4 and added a 4' pc of angle iron in the middle to stiifen. Lot less vibration now. Still pondering dropping hitch.
  10. Jun 9, 2023 at 5:16 PM
    chargedmr2
    chargedmr2 Well-Known Member
    2023 Tacoma TRD Off-Road DCLB
    Reviving old thread...
    I had the same exact issue towing today for the first time with my new TRD Off-Road. I pull a Yamaha Grizzly ATV that weight 785lbs with an 8ft Aluma trailer that weights 400lbs. So about 1200lbs total. It's pretty level with a 2" drop hitch. I would get a vibration that started at about 60-65mph. Felt like a rear tire was out of balance, but I don't think that's the case. Truck had a shake that I could really feel in the seat (not the steering wheel). I've pulled this exact setup on the same roads with a 2015 RX350 (similar 3.5 to the Tacoma) with zero issues. In fact, the RX350 did a much better job of towing and the 8 speed transmission does far better than the 6 speed auto in the Tacoma. I wasn't using ECT, so I'll give that a shot next trip out. Really an underwhelming towing experience with this truck so far, but I'll get it figured out. Probably just some user error.
    Do you guys think the vibration/shake is coming from the trailer/hitch arrangement? Too much tongue weight vs. too little? I load the ATV so about 10 percent of the total weight is on the tongue (110-120lbs).
  11. Jun 9, 2023 at 5:25 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Check the speed rating on your trailer tires.
    You'd be surprised by how many tires aren't even rated for 65.
    Also, when was the last time you had them balanced? Boat trailers especially will develop flat spots from sitting over winter.
    Rusty66, Clearwater Bill and hr206 like this.
  12. Jun 9, 2023 at 5:44 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Most trailer wheel/tires are not balanced. Plus they get flat spotted if not used much
  13. Jun 9, 2023 at 5:47 PM
    chargedmr2
    Just to clarify, I’m not the OP. I revived his thread since I have the same issue.
    My trailer (not a boat trailer) has good radial tires that were balanced about 6 months ago. I pulled it with our Lexus RX 350 two weeks ago. No issues whatsoever up 70 plus mph. Pulls like a dream, honestly. But not with the Tacoma, unfortunately.
  14. Jun 9, 2023 at 7:23 PM
    chargedmr2
    Well, I went back out on the highway without the trailer, and the trucks drives perfectly. Maybe I threw a weight on a trailer tire? Will have to do some more trial and error to see what’s up.
  15. Jun 10, 2023 at 6:09 AM
    zoo truck
    None
    I can tell you without any weight/empty in my 5x10 utility trailer, it will start bouncing if I go over 65 mph. You can feel through the cab. I'm guessing the trailer is too light for the air pressure in the tires.
