Towing weight - help
Discussion in 'Towing' started by Ydshuler, Oct 6, 2012.
  1. Oct 6, 2012 at 10:33 PM
    Ydshuler
    Ydshuler [OP] New Member
    South Carolina
    Prerunner double cab
    Running boards, after market hitch
    I have a 2007 Prerunner which did not have a towing package. It has a 5 speed automatic transmission. I had a class III hitch installed and recently purchased a travel trailer. Dry weight of the travel trailer is 5100 lbs. I did have a braking system installed and was informed by the place where I bought the trailer that the truck should pull it with no issues. After reading some of the posts on here, I am worried that I may damage my truck. I pulled it home with no issues, but as some have stated we knew it was back there. As you can tell, I don't know much about towing with this truck. I drove it home with the transmission in "D", and from the other posts apparently it should have been in "4" so the overdrive would not kick in. Am I pushing my truck past its limits?
  2. Oct 7, 2012 at 5:20 PM
    Ydshuler
    South Carolina
    Thanks for the reply. Will get one on it ASAP. So you believe the Tacoma should have no major issues pulling it? Probably won't pull it over 100 miles at a time. Again thanks for the response!!
  3. Oct 7, 2012 at 5:26 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You will be fine as long as you get a tranny cooler. Like whipper said, put it in 4 if your towing through hills.
  4. Oct 7, 2012 at 5:44 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    keep her maintained! do the tranny cooler, look into synthetic auto fluid.
    and the most important thing is to take it easy! hard starts just stresses everything out, and plan for your stops.
    even with trailer brakes make your your trucks are in good shape.
    make sure you have changed the brake fluid also.
  5. Oct 7, 2012 at 5:52 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Maybe trailering is to much for you or you-re understanding. Why do not invest in a truck book and find out for yourself?
  6. Oct 7, 2012 at 6:12 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    Hey just take your time.
    don't be embarrassed to ask for help. hell get it all hooked up and if you have a mall nearby, in the after hours go practice.
  7. Oct 7, 2012 at 6:13 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Wow... what a helpful post. :rolleyes: Oh, and you're.
    OP, you're pushing the limits of your class 3 receiver. They're only rated for 5,000 lbs, 5,500 with a W/D hitch if I recall correctly. I'd lose the class III and look for an OEM class 4 for that kind of weight. As mentioned above, a tranny cooler would be a good investment.
  8. Oct 7, 2012 at 7:03 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    YES! damn good point. you can get them online but I always used harden steel shanks.
    cannot remember i think it was buyers, but there are 2" hard steel ball with 1" shank i think thats rated for 10,000 pounds.
    just don't use that cheap stuff from walmart, and keep a little grease on the ball to help it turn, and it helps hooking and releasing esp, if its in a pinch.
  9. Oct 7, 2012 at 7:43 PM
    dougtoms01
    dougtoms01 Member
    Cincinnati, Ohio
    2008 Tacoma Std Cab
    Bucket Seats
    Did you read everything here, if not that would be a good place to start.
    http://www.tacomaworld.com/forum/towing/4031-tacoma-towing-bible.html
    If you're going local only 100 miles you should be good.
    +1 on all the things mentioned, in my 4Runner I always tow using 4th unless I have 50 miles of good flat road.
    You should only tow at about 75% of what your truck is rated for.
    You should make sure your Truck GVWR is ok adding together vehicle weight, fuel, luggage, passengers and tongue weight of anything being towed.
    Definitely want the tranny cooler and maintain your tranny/differential as recommended. Don't push the mileage between servicing.
    I assume you have a good Prodigy Brake controller or similar.
    Leave lots of room, take your time and make sure your within your equipment ratings. If you're over-loaded or using the wrong towing equipment, you can kill yourself and others. Big liability too if you're in an accident in anyway and your not legal.
    Lastly, don't trust everything the RV Dealers tell you. Research it and make sure you're good to go. Check with a Hitch Installation place if necessary, they're usually pretty skilled too. Just not U-Haul :).
    Best wishes, happy camping
