Towing with a 2.7L requirements
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ORLMEDIC20, Nov 28, 2023.
  1. Nov 28, 2023 at 1:30 AM
    ORLMEDIC20
    ORLMEDIC20 [OP] Member
    2013 Toyota Tacoma TRD Off Road 4x2 Double Cab
    I have a 2013 Toyota Tacoma TRD Offroad, 2WD with a 2.7L engine. It's a basic model and it did not bring the towing package.
    I would like to tow a boat with it, 19 foot
    other than a hitch is there anything else that is recommended that needs to be added to make it tow ready?
    Thanks in advance for the help. New to the taco world.
  2. Nov 28, 2023 at 2:50 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Welcome to TW. Click around, there’s tons of info and threads on here regarding towing.
    The ‘search’ function is your friend… enjoy!
    GilbertOz likes this.
  3. Nov 28, 2023 at 3:36 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The boat length isn't important. How much will it weigh along with the motor, fuel, and anything else in the truck. Auto or manual transmission matters too. If an auto you'll need a transmission cooler.
    At best 2000-3000 lbs max trailer weight as long as you're on fairly level terrain and with nothing in the truck but a driver. You can't tow much of anything with a Tacoma AND load up the truck with a lot of weight.
  4. Nov 28, 2023 at 7:56 PM
    ORLMEDIC20
    I live in Florida, which is all flat ground. Truck has an auto transmission.
  5. Nov 28, 2023 at 8:01 PM
    EL DUDE
    EL DUDE Well-Known Member
    Send it. I had an 82 s10 with a 2.8v6 that was used for 20 years pulling a 16’ trailer of landscaping equipment. Had way less power and torque than your truck has and did the job in Ohio and Kentucky hills.
