Towing with a 4 cylinder. What do you tow?
Discussion in 'Towing' started by mudrider300wsm, Feb 5, 2012.
  1. Oct 11, 2016 at 9:13 AM
    #41
    Nsnyota
    Nsnyota A70 are cool
    Vic
    Ontario CND
    2015 4x4 manual Tacoma access cab base model
    Thanks guys. When I load the car on. Should it sit further towards the back on the trailer/axels to help out with the weight transfer?
    What's the stress on the motor gonna be. Is gonna be hamer to the floor the whole time in 4th gear ?
  2. Oct 11, 2016 at 9:18 AM
    #42
    tgear.shead
    tgear.shead Well-Known Member
    If you load the car too far back, it will be unstable and could sway and possibly kill you on the highway. I suggest keeping the tongue weight as high as you can, but measure it so you don't go too high. You can use a cheap bathroom scale, with a pipe and a 2x4 to alter the load on the scale to match up to its range. Check google for how to do that.
    Stress on the engine will be increased during acceleration, but not significantly different once up to speed. Use 5th gear as normal for cruising on flat, downshift on slope as needed.
  3. Feb 26, 2017 at 12:49 PM
    #43
    AndreiJ
    AndreiJ New Member
    Andrei
    2004 Toyota Tacoma SR5 4X4. 2.7L
    Bedliner, tow package, and some cool stickers
    I brought home my new 16'6" smoker craft with a 40 hp mercury last night from Oregon to Olympia. I maintained 75 mph the whole way dropping to 4th on the grades. I have a 4x4 so I use 4L if I come to a redlight on a steep hill.
    exploringcarolina and specter208 like this.
  4. Jun 18, 2017 at 3:30 PM
    #44
    baldymountain
    baldymountain New Member
    1998 Tacoma V6
    Okay, so this was a bit stupid. Picked up this boat in southeastern BC, towed it all the way across the province to Vancouver Island. And there are a LOT of mountains in BC. Spent lots of time in 1st gear but we made it. This was taken on top of Kootenay Pass
  5. Feb 25, 2020 at 2:41 PM
    #45
    Steven07
    Steven07 Well-Known Member
    Steven
    2017 Gray SR5 Tacoma
    3in front lift, 2.5 rear lift
    15ft skiff. Can't even tell it's back there
  6. Feb 25, 2020 at 3:30 PM
    #46
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
  7. Mar 2, 2020 at 6:31 PM
    #47
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Actually would recommend to use 4th gear. Even on a 5-speed manual. Don’t know what trans he has, but on some older land cruiser models with 5MTs, trans will fail because towing in 5th puts too much load on 1st gear thrust washer causing it to grenade and punch a hole through housing, draining all the oil and the heat destroys trans.
  8. Sep 9, 2020 at 8:44 AM
    #48
    lennyk
    lennyk Well-Known Member
    Mountain Top, PA
    Magnetic Gray Metallic
    GOOD NEWS !!!!
    What Are The CAMPERS You All Pull With Your 4 Cylinder Tacos???
    I Was Hoping To Get A "Mini" Camper But Wasn't Sure It Would Tow...:burnrubber:
  9. Sep 30, 2020 at 12:16 AM
    #49
    Chefwicky666
    Chefwicky666 New Member
    Chadwick
    97 Toyota Tacoma 4×4
    My name is Chad!
    Just bought a 16ft scamp, fiberglass trailer, dry 1400 lbs, wet upwards of 2000.
    Want opinions on towing with my 2.7.
    Its a 4x4, 5 speed man. 97.
    We are shipping up to WA from CO.
    Would love to hear from yall. My first posting
    mic_sierra and exploringcarolina like this.
  10. Sep 30, 2020 at 4:52 PM
    #50
    specter208
    California
    Well within your towing range. Drive at 55-60 mph in 4th gear or direct drive .
    AxisCab likes this.
  11. Sep 30, 2020 at 8:32 PM
    #51
    specter208
    California
    Do not use 5th on the freeway. Stay in 4th gear and reduce your speed if you don’t want your RPMs too high. Your engine will cool more and produce power more efficiently. Your trans will also be healthier, less shifting and less load if you keep in 4th gear.
  12. Oct 2, 2020 at 2:12 PM
    #52
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Add fresh goop to that gear box. Change fluid service internal and send it.
  13. Oct 2, 2020 at 2:16 PM
    #53
    Toyotadilly
    Dillynn
    Sarasota,fl
    Add- a- leaf mabye. If you don’t want to do all that then a over the leaf helper is simple. Mabye look into sumo spring progressive bumps or timken bumps( better tow reviews on here)5100’s out back never hurt.
  14. Nov 17, 2020 at 4:44 PM
    #54
    Egghauler
    Egghauler Member
    2016 SR5 AC 2.7 Auto
    Another fiberglass egg here (16 foot Casita). The 2.7 averages about 19 mpg at 60mph in S5 on the interstate.
  15. Jul 12, 2022 at 9:21 AM
    #55
    Lostmy65
    Lostmy65 New Member
    Robert
    I found this thread using Google searching 2wd 4cyl Tacoma towing.
    I know it says 3500, but what does that feel like on the highway or going up and down hills. I live in the Portland Oregon area and we have a lot of inclined highways.
  16. Jul 12, 2022 at 11:25 AM
    #56
    Nessmuk
    Nessmuk Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
    I just finished a two week trip from central Virginia to Nova Scotia Canada. We covered a bit over 2600 miles towing. I have a 5 speed standard. On flat stretches of Interstate I did use 5th gear at times and ran at about 2500 rpm in that gear. I averaged right around 17mpg.
    At no time in the trip did I feel the truck wasn’t up to the job. The tab weighs around 2900 fully loaded.
  17. Jul 12, 2022 at 12:05 PM
    #57
    Lostmy65
    Lostmy65 New Member
    Robert
    Yeah, reading this thread, it seems like everyone is doing fine with their 4cyl. I mean, it's not a daily thing, but a few trips to the mountains to go camping it can handle.
    Thanks.
    Here's what I'll be towing maybe 8 times a year - but probably no more than a 3 hour drive. 1967 StarCraft Aluminum - with a 75hp Suzuki.
  18. Jul 13, 2022 at 4:26 AM
    #58
    exploringcarolina
    exploringcarolina Well-Known Member
    Bill
    North Carolina
    Towed this Kendon single trailer with a CB500X to the mountains yesterday, handles great:
    mic_sierra likes this.
  19. Jul 13, 2022 at 5:48 AM
    #59
    TonyG2
    TonyG2 Active Member
    2020 Tacoma SX
    Towed my 17ft skiff to Florida from north of Atlanta. I regularly tow it to Lake Lanier.20200727_110427.jpg
