towing with a lift (3 or 6 inches)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by formulabird1997, Mar 30, 2011.
  1. Mar 30, 2011 at 6:59 PM
    formulabird1997
    formulabird1997 [OP] Well-Known Member
    Greg
    shaw afb, sc
    2010 tacoma trd sport
    Kobalt compact tool box, Rear spring tsb
    Has anyone towed a heavy load with their lifted tacos? Mine is at stock height right now and tows pretty well for my needs but i'm wondering how it will be affected with a 3 inch lift or a 6 inch lift. i'm mainly concerned if the tongue weight will make the truck more nose high than it would be if it were stock. Also, does it still hold its gear (automatic) or does it hunt more trying to keep a steady speed on the highway with the stock gears in the rear end. If so, pics would help too, thanks
  2. Mar 30, 2011 at 7:01 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
    Stock suspension leaves you with a rake (higher in the back than front) so ideally the weight makes your truck sit somewhat level. With suspension lifts, it levels your truck, so with weight on the trailer, it will sit nose high.
