towing with a lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigmanr6, Jan 1, 2010.
  1. Jan 1, 2010 at 7:17 PM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    Great point!!!
  2. Jan 1, 2010 at 7:20 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I'm lifted a couple inches and my boat trailer with 13" wheels tows level with a straight hitch...
    ...while my 5 x 8 with 15" wheels takes a 6" drop...:goingcrazy: I'm running an Air Lift system too...no saggy butt.:)
  3. Jan 1, 2010 at 7:26 PM
    bigmanr6
    bigmanr6 [OP] Well-Known Member
    IL
    06 quad cab long bed speedway blue 4x4
    bhlm,grillcraft grill, toytec ultimate lift, dakar leaf pack, 5100's
    I think Ill be alright towing this is a heavy boat thats for sure 3800 lbs. I think the skyjacker with aal is the kit I may try.
  4. Jan 1, 2010 at 8:00 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    It's a 16' Smokercraft Alaskan that's filled up with fishing gear. I'm not sure of the weight, but it's fully loaded and then some.
    I forgot to mention in my earlier post that I have the weight of a Snugtop canopy on the back of my truck also.
  5. Jan 1, 2010 at 8:35 PM
    bigmanr6
    IL
    Ya it doesn't look like your truck squats at all.
  6. Jan 1, 2010 at 8:54 PM
    bigmanr6
    IL
    Were did you get you're differential drop at?
  7. Jan 2, 2010 at 10:23 AM
    rickabev
    rickabev Member
    Ann Arbor, MI
    06 Taco Sport
    3" Toytec lift Leer Shell Alpine CD w/ Sirius Satellite Polk Audio momo speakers Kenwood 8" powered sub Airlift Airbags at rear with on board compressor with remote control K&N Replacement Filter BFG All-Terrain Tires
    I have an '06 DC short bed that I put a 3" Toytec lift on and I also added airride bags to balance out the truck when I have a load in it. Works great. I attached a photo of my trailer that I tow. I towed without the airbags and they definitely make a good difference. Trailer weighs appx 3800lbs dry, so about 4800lbs loaded.
  8. Jan 3, 2010 at 10:02 AM
    bigmanr6
    IL
    That's about what mine weighs and pulls like did you do the aal or just keep stock stuff with the the bags?
