Towing with a Manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by prefersdirt, Jun 8, 2021.
  1. Oct 14, 2023 at 8:57 AM
    #41
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Thank you! Yep, tires are 265/70 Nitto Terra's.
    Pwakchop[QUOTED] likes this.
  2. Oct 14, 2023 at 12:18 PM
    #42
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Awesome, thanks. And, for the hood/bug guard, how are you liking it? Probably going to grab one soon.
  3. Oct 20, 2023 at 12:46 PM
    #43
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    It’s a harness with wires that plugs into the stock 4WD ECU. A member used to make them on here.
  4. Oct 20, 2023 at 12:47 PM
    #44
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Love towing with my manual.
    02Duck[QUOTED] and 33yrsoftoys like this.
  5. Oct 20, 2023 at 12:49 PM
    #45
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    For the cost and ease of installation I think it’s a no brainer.:)
    I use mine even when backing up unladen uphills, just saves the clutch. Aaaand you get the chance to cycle the actuator.:)
  6. Oct 20, 2023 at 12:54 PM
    #46
    Sungod
    Sungod Well-Known Member
    St Augustine
    I don't know if you are planning on towing 6000 lbs on a regular basis, but I would be looking for something bigger. You will be buying a new clutch on a regular basis.
    Junkhead likes this.
  7. Oct 20, 2023 at 1:02 PM
    #47
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    ~4K# is most I would tow on a regular basis.
    33yrsoftoys, Irons and Sungod[QUOTED] like this.
  8. Oct 24, 2023 at 7:14 AM
    #48
    prefersdirt
    prefersdirt [OP] Well-Known Member
    2019 tacoma Sport
    so no chance of getting one now?
  9. Oct 24, 2023 at 7:20 AM
    #49
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
  10. Jan 19, 2024 at 6:07 AM
    #50
    prefersdirt
    2019 tacoma Sport
    Popping this back up as spring is coming and the 2Lo is a mod I would use a LOT. Anyone know of someone around Indianapolis that could install it? Might not be hard but time is an issue. Thanks
  11. Jan 19, 2024 at 6:08 AM
    #51
    BLtheP
    Plano, TX
    I would say install is like an hour. I could personally do it in about 10 minutes now because of how many times I’ve torn apart the dash in that area. If time is really so tight that you can’t spare an hour or two, you could probably find someone nearby from the forum to do it for you.
  12. Jan 19, 2024 at 6:24 AM
    #52
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Agreed. To add to your post.... the automatic has the ability to lock and unlock the torque converter. When the converter is locked an auto operates like a manual in that the flex plate and the output shaft are 1:1. When the converter is unlocked, massive amounts of heat are generated in the converter whilst under load because of fluid coupling. The engine transfers power through a series of turbines which compress (move) the ATF which then turn the output shaft. Heat is generated as a byproduct of this transfer. MASSIVE heat if you are at a mechanical disadvantage (overdrive gears, going up hill, pulling a load). You do not have this issue in a manual as your foot on the clutch is the only coupling device between the engine and the transmission. You don't have the ability to lock and unlock a torque converter and you don't have to worry about the heat generated with fluid coupling because there is no fluid coupling.
    Your concerns are the same as any manual trans driver: rev matching, don't slip/burn the clutch etc., keeping the taco in the proper rpm range (don't lug it up hills), etc.
    doublethebass likes this.
  13. Jan 19, 2024 at 6:36 AM
    #53
    prefersdirt
    2019 tacoma Sport
    if there was a video showing me how, I could probably do it. I am NOT a car/truck guy, so that knowledgebase is not in my head. Thanks
