Towing with a SC
Discussion in 'Towing' started by ATHiker, Jun 19, 2013.
  1. Jun 19, 2013 at 7:35 AM
    ATHiker
    ATHiker [OP] Well-Known Member
    Tom
    Tennessee
    15 Tundra DC 4X4 SR5 OR 5.7L
    I have a 2013 DC TRD Sport (auto) with factory towing package. Would the addition of a SC reduce the build up of heat in the automatic transmission when towing by reducing the locking / unlocking?
  2. Jun 19, 2013 at 8:21 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    No. It will be hotter because it is putting even more torque through.
    On mine, I don't tow in OD... saves the trans whether manual or auto.
    It made a big difference in capability, though! Best investment ever:D
  3. Jun 19, 2013 at 8:26 AM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    Definitely a great investment. Now when pulling my boat it's almost like its not even there
  4. Jun 19, 2013 at 8:46 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I'd consider an external trans oil cooler (B&M or similar, with bypass) with a temp gauge and external filter for added protection if you are going to do any heavy towing/hauling, S/C or not. For a couple hundred dollars you can ensure your auto trans is well-protected, seeing as they are expensive and not easily fixed in your garage.
    There's a thread on TW I was reading awhile back that had a very good discussion on the subject.
  5. Jun 19, 2013 at 7:23 PM
    ATHiker
    Tom
    Tennessee
    Thanks for the replys.
  6. Jun 19, 2013 at 7:58 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    The tow package comes with a transmission oil cooler doesn't it?
  7. Jun 20, 2013 at 9:59 AM
    YOTA LOVER
    NH
    Yeah, but from what I gathered its a bit half-assed as its co-located/built in with the radiator and would operate better relocated in front of the radiator.
  8. Jun 20, 2013 at 4:50 PM
    ATHiker
    Tom
    Tennessee
    I would add an external transmission oil cooler, but I don't want to void the warranty. Wonder if a deal would install one? I really want a SC!!!!!
  9. Jun 20, 2013 at 4:59 PM
    YOTA LOVER
    NH
    Yeah, we hit on this subject in the trans cooler thread. If anything, it's better for the system, but I might hold off until the warranty expires.
  10. Jun 22, 2013 at 11:57 AM
    F-125Racer
    F-125Racer Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    Yes, it reduces the locking/unlocking.Trans heat stays about the same. Don't over-think this, the tranny will put up with a lot. I tow 5,400 lbs fairly often and flog the truck pretty hard. Never an issue. Trans fluid still smells fine at 62,000 miles. Toyota tech told me towing in OD is not an issue, so that's what I do. I do go to 4th if it starts hunting for a gear.
