Towing with a Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yaya, Dec 22, 2014.
  1. Dec 22, 2014 at 4:57 PM
    Yaya
    Yaya [OP] New Member
    Florida
    Tacoma 4x4
    I have a 2013 Tacoma 4x4 Double Cab long bed and want to tow a 2007 Infiniti G35. Is there anything special I should do first?
  2. Dec 22, 2014 at 5:10 PM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    Depends on how far.
  3. Dec 22, 2014 at 5:12 PM
    txrowdy
    txrowdy Well-Known Member
    Taylor
    Maui, HI
    08 SR5 4x4
    3" ICON Stage 3, Pelfreybilt Front Bumper, Skid, Sliders, Prinsu Roof Rack, Bed Tool Mount Mod, Interior LEDs, Wet Okole Seat Covers
    What kind of trailer. Single or dual axle? Electronic brakes?
  4. Dec 22, 2014 at 5:13 PM
    mdne04
    mdne04 Well-Known Member
    Eduardo
    Weslaco, Texas
    DCSB TRD Off-Road 4x4
    OME 3" kit (885's), LR-UCA's, Dakars, Ext. rear brake lines
    Confirm that you have the towing package. If you do then start calculating weight, I believe 6300lbs is the max weight. If you don't have the tow package then I would take in to consideration how far you'll the towing the G35. Just my 2 cents.
  5. Dec 22, 2014 at 5:31 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    3rd Gen Tundra WCP TRD OR I-Force Max
    Close 6500 lbs for short bed and 6400 lbs for long bed:
    http://www.toyota.com/content/ebrochure/2013/tacoma_ebrochure.pdf
  6. Dec 22, 2014 at 6:03 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    If you have an auto, keep it in fourth gear on the highway, and third gear around town, and take it easy. This will keep the torque convertor locked. This will keep your trans fluid cooler and keep you from cooking your trans. It'll heat up fast unlocked...
    If you have a manual, never mind.
  7. Dec 22, 2014 at 6:19 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yeah, that's true. As long as you drop it down into 4th on a hill or, like RL said, if the trans starts "hunting". I can monitor trans temp with my ScanGauge at the pan and the TC and switch gears when needed. I wouldn't expect you to buy a SG for one towing trip. 4th is a fail safe.
  8. Dec 22, 2014 at 6:25 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    If you get a uhaul car carrier chances are it will come with surge brakes. They are automatic and are engaged when braking as the trailer (essentially pushes forward against your truck)
    You should be well within the 6300lb towing capacity assuming you have the tow package
    No need for an electric brake controller
  9. Dec 22, 2014 at 7:41 PM
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    I towed an SC400 from D.C. to Detroit, through the mountains and all on a Uhaul trailer (5600 lbs). Kept in 4th (auto) cruising btwn 60-65MPH, no issues at all... I do run Amsoil in the trans and according to Torque-pro Android app trans temp stayed around 170F.. I did order a larger B&M trans cooler but it's not necessary... take it slow and keep your distance... cheers
  10. Dec 22, 2014 at 9:43 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    5th is fine if you like buying trannies! Check this forum (and others) lots of info on this topic. 5th gear is not strong enough for towing and over time you will grenade 5th gear if you tow much weight at all. Tow in 4th and you will usually get better mileage than you do with 5th and your tranny will be much happier. Scan Gauge doesn't help as it is not a tranny temp issue, it is a "small sized weak gear" issue.
  11. Dec 22, 2014 at 9:57 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Doubt your flat towing, but Dolley? Trailer? How far is it going? Brake controller is a good idea if it's going on a trailer unless by odd chance it has a surge brake. Dolley, tie off steering wheel remove cars drive shaft and use wheel straps or load it backwards if not gong to far and again tie off the steering wheel
  12. Dec 22, 2014 at 10:03 PM
    ObiWan Tacomi
    ObiWan Tacomi Well-Known Member
    Joe
    NYC
    '13 DCSB Tacoma TRD OffRoad
    Airaid Intake Magnaflow Exhaust Icon Coil Overs (ride quality is amazing) Icon AAL Icon Rear Resi's BruteForce Hybrid Front Bumper Ghost Raptor Grille Raptor Lights Debadged
    Depends on where you're towing too, but make sure you criss cross the "safety chains" before you start your journey. Up here in NY the highway troopers are notorious for writing tickets if they're not criss-crossed.
  13. Dec 23, 2014 at 4:31 AM
    teneighty
    :confused:
  14. Dec 23, 2014 at 9:27 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
  15. Dec 23, 2014 at 12:14 PM
    RKCRUZA
    Bob
    Placerville, Ca
    You think? Same manual that they never bother to change? When I got my Tundra I called Toyota directly and was told sure, it's OK to tow in OD, just kick it off if you are in the hills. 2nd trip to Moab kissed OD goodbye and Toyota bought me a tranny at 35k miles. Had a talk with my buddy Marlin at Marlin Crawler (he knows a wee bit about trannies) and he told me to never tow in OD due to the weak gear etc. If you are towing some little thing it is most likely OK, but if you are towing anything that weighs much use OD at your own risk. There is a lot on this forum about this issue and a good picture of what towing can do to 5th gear.
  16. Dec 29, 2014 at 1:37 PM
    Yaya
    Florida
    Tacoma 4x4
    Thanks for all the help everyone! I tried to rent an auto hauler from u-haul but they said my 2013 Tacoma double cab 4x4 long bed wasn't rated to tow a 2007 infiniti g35 coupe the 550 miles I need to go so they wouldn't rent me one. So now I am trying to figure out if I can tow my Tacoma on a tow dolly behind my 38' Winnebago (Cummins Turbo Diesel). I called the local Toyota dealership and asked about having the 4x drive shaft removed and putting her on the tow dolly but the nimrod told me I can NOT tow my Tacoma unless it's on a flat bed. What to do?
  17. Dec 29, 2014 at 1:41 PM
    Yaya
    Florida
    Tacoma 4x4
    Thanks for all the help everyone! I tried to rent an auto hauler from u-haul but they said my 2013 Tacoma double cab 4x4 long bed wasn't rated to tow a 2007 infiniti g35 coupe the 550 miles I need to go so they wouldn't rent me one. So now I am trying to figure out if I can tow my Tacoma on a tow dolly behind my 38' Winnebago (Cummins Turbo Diesel). I called the local Toyota dealership and asked about having the 4x drive shaft removed and putting her on the tow dolly but the nimrod told me I can NOT tow my Tacoma at all unless it's on a flat bed. He didn't instill much confidence so I am wondering if this is true.
  18. Dec 29, 2014 at 2:57 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Tell UHAUL you're towing a VW Bug...
  19. Dec 29, 2014 at 3:50 PM
    teneighty
    Seriously, they don't need to know WTF you're towing
  20. Dec 29, 2014 at 4:56 PM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    They have guidelines which they HAVE to follow in accordance with corporate.
    Take Walmart. They would not mount any tire on any vehicle other than oem spec because of the lawyers. I bought larger than oem on my Dakota from Walmart. Had to go down the road and have them mounted and balanced.
    After 30 years as an insurance agent, I want to personally choke out every personal injury attorney. A percentage of everything you buy is built in cost because of them and lottery mentality low life's trying to get rich without really working or at least trying
