Towing with a zero offset
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rileycn513, Sep 22, 2022.
  1. Sep 22, 2022 at 1:58 PM
    Rileycn513
    Rileycn513 [OP] Member
    Cincinnati, OH
    2022 Magnetic Silver Tacoma SR
    I recently bought some 16/8 rims with a zero offset for my 2022 Taco SR. Ive looked through these threads and havent found anything that spoke directly to this question.
    I know Tacomas come with a stock 25 offset. Ive also ready that going negative on offset was potentially bad for your bearings and axle.
    If i have new rims with a zero offset, will that impact my towing and payload capabilities? Ive read that big negative offsets may impact your truck's load ratings, but not sure if going from 25 to zero offset was enough to cause concern.
    Will my rim change impact the payload of my truck, thus forcing me to take more concern to my tongue weight of my camper than if it were still stock 25 offset?
    I apologize in advance if this has been answered and i missed it. Hopefully my questions is clear also. This is my first real truck and first year of towing a camper, so im still trying to learn the ins and outs of how modifying my taco will impact things.
  2. Sep 22, 2022 at 2:05 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Since the non TRD Pro wheels running an offset in the +25 area and the TRD Pro's running a +4 offset have the same wheel bearing, my guess is you are over thinking this and will be fine.
  3. Sep 22, 2022 at 2:12 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Quite a few people here are running
    Where did you read the article about negative offsets?
    Junkhead and hiPSI like this.
  4. Sep 22, 2022 at 2:16 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    I learned from the forums to just do and see what happens later
    Junkhead, hiPSI and oconnor like this.
  5. Sep 22, 2022 at 2:18 PM
    BrycenW01
    BrycenW01 Member
    Brycen
    06 DCLB
    I have towed up to 6K with -9 offset wheels, you'll be fine
    Rileycn513[OP] likes this.
  6. Sep 22, 2022 at 2:38 PM
    Rileycn513
    Cincinnati, OH
    This is exactly what I wanted to hear.
  7. Sep 22, 2022 at 2:41 PM
    Rileycn513
    Cincinnati, OH
  8. Sep 22, 2022 at 2:42 PM
    Rileycn513
    Cincinnati, OH
    Thank you. I didnt realize the Pro's had +4. This helps and sorry for the noob question. Im always guilty of overthinking unfortunately.
    RustyGreen and Junkhead like this.
  9. Sep 22, 2022 at 3:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    They are correct technically but not practically. Sure, run some of big neg offset and of course your wheel bearings will have a higher load and poof your wheel bearings have reduced life.
    Same for hauling a high payload. If you have two stock trucks, one with a thousand lbs in the back and the other one empty and they drove like that for years the one with the load will wear out his wheel bearings faster.
    You have an intermittent short term load. You are moving the cl of the wheel very slightly.
    You will be fine lol.
    Junkhead and Big tall dave like this.
  10. Sep 22, 2022 at 3:30 PM
    CrispyTacoLover
    There are hundreds of people here running -10mm wheels from SCS and other makers. If anything, the slightly wider stance provides some stability during towing. I never towed more than 3500 pounds but it was fine.
  11. Sep 22, 2022 at 3:34 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Tbh having a wider stance should make the load more stable, especially if you go wider. The only issue with what you said in the OP pertains to the extra stress the steering components can be under when turning. Should be more than okay on a solid axle setup. Just make sure the wheels/tires you choose have a proper load rating to support whatever you are going to be towing.
  12. Sep 22, 2022 at 5:44 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    16x7 +25
  13. Sep 22, 2022 at 5:47 PM
    Rileycn513
    Cincinnati, OH
    the Pros are +4. Someone else commented with that info. I wasn’t aware but gives me reassurance.
  14. Sep 22, 2022 at 5:48 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    Seems like about half the country is doing a terrific job of not thinking at all -- a little overthinking is the better way to be. :thumbsup::thumbsup:
  15. Sep 22, 2022 at 6:09 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    You're right- oops. Pros are +4 as mentioned tho. I'm sure OP will be fine regardless.
  16. Sep 22, 2022 at 7:20 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Yup. But he specified OR. Offset is one of the ways Toyota markets the Pro to look tougher.
