Towing with and without a weight distribution hitch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spielightdude, Jul 7, 2021.
  1. Jul 7, 2021 at 2:27 AM
    Spielightdude
    Spielightdude [OP] Well-Known Member
    Joseph
    Canterbury
    2023 TRD Offroad
    Good morning everyone,
    I am wondering if using a weight distribution hitch for a travel trailer makes any difference in stability, safety and towing capacity?
    Thank you
  2. Jul 7, 2021 at 3:02 AM
    William H. Bonney
    William H. Bonney Well-Known Member
    2016 TRDOR
    How big is this trailer?
    Paulndot likes this.
  3. Jul 7, 2021 at 5:01 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  4. Jul 7, 2021 at 5:01 AM
    Spielightdude
    Joseph
    Canterbury
    2023 TRD Offroad
    Don't have one yet but planning on a travel trailer around 5000-6000 lbs fully loaded
  5. Jul 7, 2021 at 5:24 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    HUGE DIFFERENCE! I tow a Grand Design 17MKE at about 5,100 lbs.
  6. Jul 7, 2021 at 5:26 AM
    jbjones85
    jbjones85 Well-Known Member
    Josh
    Newburyport, MA
    for sure!
  7. Jul 7, 2021 at 5:44 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Stability and safety - Yes
    Towing Capacity - Hard No.
  8. Jul 8, 2021 at 7:52 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    ^^- Agree with this.
    Knute likes this.
  9. Jul 8, 2021 at 8:01 AM
    KingJeff813
    KingJeff813 Well-Known Member
    Wisconsin
    2020 Alfa Romeo Giulia Ti Sport Q4
    Traded it in.
    I use my WDH with a sway bar every time I tow my travel trailer. Its only 3200ish dry and 23 feet, but they make a huge difference. I don't think I'd tow it without them. Doesn't add any towing capacity but diffidently adds alot of safety and stability.
    TacoManOne likes this.
  10. Jul 9, 2021 at 4:51 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Good point!
    I glossed over the capacity part
    Rock Lobster[QUOTED] likes this.
  11. Jul 9, 2021 at 5:12 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Don't remember where exactly I read this, but I distinctly remember reading a couple of articles that stated if you are towing anything above 3,000 lbs loaded you should be using a WDH. I'm sure others can verify whether this is actually true or I was having a senior moment.
  12. Jul 9, 2021 at 7:04 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Rule of thumb I always heard was anything above 60% of capacity it's strongly recommended to run a WDH. For the Tacoma, that's a gross trailer weight of 4000 lbs. So essentially, any camper that has a dry weight of 3000-ish or greater should have one.
    I would go one step further and say that any (non-folding) camper, due to their low density and high wind profile, needs sway control. And if you're going through the extra steps of hooking up a sway bar, you might as well just get a WDH.
    tonered and Chew like this.
  13. Jul 9, 2021 at 7:09 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Please do not forget the weight of the WDH will be part of the cargo weight on the truck.
  14. Jul 9, 2021 at 7:11 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    When I was towing a 32 footer with a 3/4 ton Suburban, I used a dual cam Draw-Tite. It provide weight distribution as well as anti-sway control and a plus was you could backup with it fully connected. Some anti-sway device require you to disconnect them when backing.
    tonered likes this.
  15. Jul 9, 2021 at 9:12 AM
    slapntz
    slapntz Well-Known Member
    Get an Andersen - they are super light (relative to the other options).
  16. Jul 9, 2021 at 9:47 AM
    LDrider
    LDrider Well-Known Member
    New England
    2019 SR 2.7 Access Cab 4x4 (sold to Carvana!)
    Believe it or not, the Tacoma's owners manual has a section on towing and explains VERY clearly the requirements (even gives math examples) of how to setup your Tacoma for towing ;-)
  17. Jul 9, 2021 at 10:43 AM
    androofoo
    androofoo Well-Known Member
    2018 Tacoma TRD Off-Road Cement
    Is the WDH required for trucks with airbags?
  18. Jul 9, 2021 at 10:46 AM
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    What is this "Owners' Manual" you speak of?
    :p
    LDrider[QUOTED] likes this.
  19. Jul 9, 2021 at 10:47 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Yes. I wouldn't even think of going over 4500lbs without one.
  20. Jul 9, 2021 at 10:52 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    yep. a WDH is much more effective at distributing the load than bags. bags dont negate the need for a WDH when youre towing "heavy" (heavy being relative to the trucks tow capacity)
    Chew likes this.
