Towing with backup camera
Discussion in 'Towing' started by jim5426, Jun 19, 2014.
  1. Jun 19, 2014 at 9:17 PM
    jim5426
    jim5426 [OP] Member
    jim
    north carolina
    2014 Tacoma, double 4x4 v6
    I have a backup camera on tailgate and monitor on radio face inside. Is there anyway to adjust camera to see ball and trailer tongue as I'm backing into position to connect the trailer?
    NEVER MIND IT WORKS FINE, MUCH BETTER THAN I THOUGHT. I'M VERY PLEASED WITH THE ACCURACY OF BEING TO LINE UP BALL AND HITCH..:D
  2. Jun 19, 2014 at 9:20 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    It kinda already does that. Are you asking about when the tailgate is down? If so, then no. I have pondered on how to make it happen with the tailgate down but no luck yet.
  3. Jun 19, 2014 at 10:04 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  4. Jun 19, 2014 at 10:09 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I have the factory one and I can see the hitch....
  5. Jun 19, 2014 at 10:18 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yep
  6. Jun 19, 2014 at 10:25 PM
    medic2230
    Murph
    Bama! Roll Tide
    Mine does that now. I've always backed up fine with it where Toyota put it.
  7. Jun 20, 2014 at 8:03 PM
    jim5426
    jim5426 [OP] Member
    jim
    north carolina
    I'll have to try it out (just got it) by looking at the camera location it doesn't seem like it would point down far enough to actually see ball and hitch alignment.
  8. Jun 20, 2014 at 9:25 PM
    User Name01
    Bolbi Stroganovsky
    It does, I use it every weekend.
  9. Jun 21, 2014 at 7:19 PM
    jim5426
    jim5426 [OP] Member
    jim
    north carolina
    YOU ARE RIGHT!
  10. Jan 4, 2016 at 6:09 PM
    Mark996
    Mark996 Member
    Lothian, MD
  11. Jan 4, 2016 at 9:59 PM
    koditten
    Kirk
    Central Michigan
    There was room beside the handle to drill a hole in handle trim.
  12. Aug 13, 2017 at 11:47 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    It's easy to use the camera to align the hitch from side to side, but knowing when to stop reversing so the ball is at the perfect spot under the trailer tongue is harder since you can't see it in the camera when it goes under the tongue. I put a small whiteout stop line on the top of the exactly where the forward edge of the tongue is over it (from the camera's angle of view) so I can see exactly when to stop reversing with the camera - perfect front/back and side alignment in just one try now!
  13. Aug 15, 2017 at 5:33 AM
    Indy
    Indy Master of all I survey.
    Balls are round and the trailer is onwheels7, you just need to have the hitch roughly in the right spot and it will center itself .
