Towing with heavy tongue weight
Discussion in 'Towing' started by StG, Apr 6, 2023.
  1. Apr 6, 2023 at 11:26 PM
    StG
    StG [OP] Well-Known Member
    Valley of the Sun, AZ
    15 DCSB TRD
    I plan on towing a 5x10 utility 'camping' trailer with a motorcycle loaded up front cross-wise, which will undoubtedly result in a tongue weight over the recommended 10-15% overall trailer weight.
    Anyone see any issues I might have as long as the tongue weight still stays within the tacoma rating? Also wondering how folks would recommend carrying other heavier items on the trailer (like gas/water cans, propane tanks, coolers). Over the axle, slightly behind the axle, or in the rear of the trailer (to offset the front load)? Thanks!
  2. Apr 6, 2023 at 11:37 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    HondaGM and mic_sierra like this.
  3. Apr 7, 2023 at 6:57 PM
    PatZ
    PatZ Active Member
    2023 Ford F150 Lariat
    That Towing Bible doesn't answer the question he's asking. The question is (and correct me if I'm wrong) if you have the trailer loaded and all the numbers fall within the Tacoma's ratings, but the tongue weight is more than 15% does that negatively impact the vehicle's performance? ex: you're towing a loaded trailer weighing 2000 lbs but the tongue weight is 400 lbs (20%). It's just you in the truck and the weights are well under the limits otherwise, will this hurt anything?
    I'm honestly curious if anyone has an answer here because I've looked up that question plenty of times and found absolutely no answer to that. The closest thing people have mentioned is the dangers of overloading the axles or going over the max tongue weight, but neither of those issues apply here.
    StG[OP] and HondaGM like this.
  4. Apr 7, 2023 at 7:02 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Too much tongue weight will lighten the weight on the steering axle and give a vague steering feeling and poor traction. Depending on what else is in/on the trailer you can creatively load it to lessen the impact of having the bike right at the tongue.
    HondaGM likes this.
  5. Apr 7, 2023 at 7:20 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the air in the rear tires.
    And take it easy in curves. The more weight on the rear the less there is on the steer axle.
