Towing with Tacoma 3.4L 6 cyl
Discussion in 'Toyota Trucks & SUVs' started by susantm, Mar 26, 2012.
  1. Mar 26, 2012 at 11:13 AM
    susantm
    susantm [OP] Member
    Susan
    Oregon
    03 Tacoma 6 cyl 3.4L
    We have a 2003 Tacoma 3.4l 6 cylinder with towing package and are buying a travel trailer. The one we chose weighs 4150 lbs, and the salesman assured us that our truck could pull it. However, I keep reading posts here and on RV.net that disagree. We pick up the trailer on Friday, and I would like to hear some feedback before then so I can either feel more comfortable with our purchase or see if we can change to a lighter trailer.
    Thanks so much! Any help is most welcome!
  2. Apr 10, 2012 at 7:16 PM
    mac424205
    mac424205 Well-Known Member
    Mathew
    Chelsea
    2005 4Runner Limited V8 4X4
    Billies on all four corners with daystar spacer lift. Bought it like this. Replacing done with toytec ultimate 3" lift
    Your truck will pull it no problem. Make sure that you get some air bags to help with the extra weight on your suspension, or helper springs. You WILL need a break controller for the breaks on the trailer.
  3. Jun 8, 2012 at 8:48 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    It will be fine. The limitations are the rear springs and possibly the brakes. Getting an equalizer hitch will make it easier. The stock taco rear springs are junk, so any upgrades back there would be a big improvement.
