Towing with. Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chungaz, May 30, 2013.
  1. May 30, 2013 at 5:19 PM
    Chungaz
    Chungaz [OP] Well-Known Member
    Rolla,Mo
    Black TRD Sport 4x4
    None YET!!!
    I'm wanting to buy a 21ft ultralite camper that weighs around 3000lbs.I have short bed sport with towing package . Will I be able to tow is safely with my truck. No mods to truck
  2. May 30, 2013 at 5:39 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    V6? Relitively flat terrain? Yeah. I4 may struggle a bit. Steep hills keep stopping distance in mind, maybe wanna upgrade front brakes if regularly hauling, or install trailer brakes if possible that would be a good upgrade anyway, a brake controller.
  3. May 30, 2013 at 5:42 PM
    tacoma1
    tacoma1 Well-Known Member
    Greg
    Blossvale NY
    17 TRD PRO
    You will have no problems at all!! I have Off Road PKG Same set up as you. TRucks rated for 6500 Trailer Weight. I tow my 27ft Pontoon Boat weighs approximately 4000. Pulls it awesome!!:D
  4. May 30, 2013 at 5:44 PM
    Chungaz
    Rolla,Mo
    Black TRD Sport 4x4
    None YET!!!
    Yes it is a V6 . Mainly highway / interstate hauling and not too frequent.
  5. May 31, 2013 at 10:49 AM
    yota243
    E.J.
    north Alabama
    No problem. I hauled a camper 80 miles with mine that weghed around 5k. It was all pretty flat no trailer brakes, and one brake pad was exploded (both inside pads wound up coming uncast somehow, I had replaced one and figured it was a freak event so didnt even check the other and had to plug a tire the other day and noticed the other had done the same. It may have done it after I hauled the trailer since it had been 3 months, but long story short I will never buy carquest brakes.)
  6. May 31, 2013 at 1:47 PM
    cjcarner
    cjcarner Well-Known Member
    Colin
    Savannah, GA
    2011 TRD Sport 6MT DCSB
    Rhino Rack roof rack with an Inno fairing, Snugtop Rebel cap
    Get a brake controller and the truck will be fine.
  7. May 31, 2013 at 2:18 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That's might light for a 21' foot what's the trailer GVW? Any thing that size will have brakes you'll need to install a controller.
  8. May 31, 2013 at 2:26 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  9. May 31, 2013 at 10:24 PM
    05TacoDblCab
    05TacoDblCab Member
    I pulled 6k lbs with mine from Alaska down to Washington state. Trailer brakes are awsome and if you can swing it get airbags. I do have them and it helps the saggy ass alot. Keep your tranny temps in mind if your auto and you'll be very happy. I drove my auto like a stick, staying out of D, and my tranny generally stayed around 175ish until I hit a fair hill or started up a pass. Then it would go around 205ish degrees Fahrenheit.
  10. Jun 2, 2013 at 12:05 PM
    bdemick
    bdemick Member
    Federal Way, WA
    2006 Tacoma Dbl.Cab 4x4 TRD
    I have a 2006 Tacoma Double Cab 4x4 Short Bed, automatic V6 with Tow Package and with two adults I tow a Keystone Passport 2650BH 26ft travel trailer. The trailer weighs 4960lbs unloaded and between 5600 & 5800 lbs loaded. I use an Equal-I-zer Brand 4 point weight distribution hitch with built in sway control and a Prodigy P2 brake controller. While this is quite a load for the Tacoma at no time does it feel unsafe, sway or bounce. I tow in 4th gear and at 60 mph I'm turning 2500 rpm. At inclines I drop into 3rd gear and turn 3000 rpm. My fuel mileage takes a big hit and I get between 10.5 and 11.75 mpg depending on inclines and road conditions. Not the ideal tow vehicle for a trailer this size, but it does an OK job. Just take your time and don't be in a hurry! The Tacoma is a beast!
    Attached Thumbnails [​IMG]
