Towing with the bumper alone?
Discussion in 'Towing' started by pennman73, Apr 8, 2016.
  1. Apr 8, 2016 at 10:19 AM
    pennman73
    pennman73 [OP] New Member
    Roger
    2001 Tacoma 4x4, 2.7 5speed, black
    none!
    I just purchased a 2001 Tacoma, 4.7, 5 speed; decent miles (88000) appears to run good.
    Notice that there is no towing hitch. The rear bumper has a 'hole' for a ball...my question, will the bumper itself meet specs for towing or I need to reinforce, or add 'something'?
    Thanks!
  2. Apr 8, 2016 at 12:15 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Welcome to the club!:thumbsup:I would suggest to get a tow package!Bumper alone doesn't meet specs!
    tcBob likes this.
  3. Apr 8, 2016 at 12:15 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW!
  4. Apr 8, 2016 at 12:16 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    2.7?
  5. Apr 8, 2016 at 12:50 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Some will say you can tow with the bumper, although certainly not the full spec. weight. Take one apart like I did and you would say differently. I wouldn't tow 300lbs on the bumper. But even beyond it's strength there are some serious flaws with towing on the bumper... One is that you will reduce your turning radius to what I consider an unacceptable amount. Another is that there are very few trailers with tires big enough to make the trailer sit level when it's on the bumper. You generally need a drop hitch unless you are running a 2wd truck and very small tires.
    I could go on, but the bottom line is this... if you are going to tow anything with regularity, no matter how light, get a proper receiver hitch installed.
    NAAC3TACO and ODNAREM like this.
  6. Apr 8, 2016 at 3:28 PM
    Indy
    Indy Master of all I survey.
    It depends on your 'specs'. The taco rear bumper is rated for class II tow, 350lbs tongue and 3500 max tow weight. More trailers have been towed on bumpers than receiver hitches. Stay at or below what they're rated for and you're fine. It was designed by engineers to work for light duty towing. If you want to go heavier you have to have a decent receiver installed.
    My last taco had a receiver installed, used it. My current doesn't, I use the bumper. When I want to tow heavy, I use my f250.
  7. Apr 8, 2016 at 3:32 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Yup, that's it. A bumper is ok for a light utility trailer if you're hauling a couple of bags of peat moss or a few 2X4.
    vssman likes this.
  8. Apr 19, 2016 at 5:13 AM
    pennman3
    pennman3 Member
    Roger
    Eastern Kentucky
    Tacoma
    Roof Rack
    thanks to everyone who provided info on my towing question: leaning towards the hitch package: any tips on best source to purchase from (online..?)?
  9. Apr 19, 2016 at 10:24 AM
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Hey Roger; there must a local welding shop/custom hitch shop in your area who can make a hitch for your truck. A custom hitch is better because the welder can make it tuck up nice and tight under the truck. Some of the after market ones don't seem to fit very well and are visible under the bumper. Also, you'll want to retain the ability to stow your spare under there as well. Good luck!
