Towing with V6 TRD Tow package
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fishontom, Sep 11, 2016.
  1. Sep 11, 2016 at 9:37 PM
    Fishontom
    Fishontom [OP] New Member
    2014 TRD DC
    I just bought a 2014 TRD 4L has the tow package oil cooler tranny cooler .... I am interest in what people have towed with them I am loking at a 19 foot fishing boat around 2800 pounds?
  2. Sep 11, 2016 at 9:50 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  3. Sep 12, 2016 at 3:35 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    2800 lbs is no problem. I tow a boat that is 3000. Mine is bass boat style so it is fairly low profile. Pontoons and taller boats add wind resistance. On fairly flat roads I tow in 5th if I can keep speed at 60+.
    Fishontom[OP] likes this.
  4. Sep 12, 2016 at 6:46 AM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Should not be a problem. Well under the rated tow weight.
    Toyko Joe and Fishontom[OP] like this.
  5. Sep 12, 2016 at 8:58 AM
    BaconPower
    BaconPower Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    Should be ok but make sure to account for the fishing equipment in your bed plus the tongue weight of the trailer (15% of 2,800lbs) when calculating weight ont he rear axle.
    Fishontom[QUOTED][OP] likes this.
  6. Sep 12, 2016 at 10:55 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Let me channel my inner tgear: don't do it unless you enjoy endangering the lives of innocents on the road.
    Really, your truck will have no problem with that. Tow in 4, not D, and trailer brakes wouldn't hurt. Tongue weight will be lower than what BaconPower is calculating as boats are typically below 10% since most of the weight is behind the trailer axle. I tow about 5,000lbs in the Sierras fairly often and the truck does fine.
  7. Sep 14, 2016 at 11:53 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    I would tow a 6000 lbs boat locally as long as I had brakes. Boats are aerodynamic, they don't cause a problem. The big 8' wide travel trailers, that's a different story, I won't go past 3000 lbs on one of them.
  8. Sep 15, 2016 at 9:56 AM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I tow a ~4000 lb camper (big front surface area). Took it out to the desert last Nov, climbing big hills with ambient temps in the high 80s, and saw the tranny temp hit 230 a couple times.
    I've since upgraded the trans cooler and can consistently keep temps below 200 with an occasional peak of 210.
    Towing your boat should be fine - both lighter and a smaller frontal area than a camper.
  9. Sep 15, 2016 at 5:18 PM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I tow a 27 ft RV. It is 4700 lbs dry weight. So likely around 5500 to 6000 with all our stuff in it. A weight distribution hitch makes things much more stable. The truck has the power. The trailer has brakes. Set the shifter to 4th and set the cruise to 60 and enjoy the ride. The truck will pull the trailer across the country without a hiccup. Ok maybe the mountains might make things more interesting. Just a great truck all around.
  10. Sep 15, 2016 at 5:31 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Shouldn't be an issue. I tow a boat every weekend that's about half that weight and don't feel it at all.
  11. Sep 16, 2016 at 9:20 AM
    Wmck
    Wmck Member
    2012 Tacoma PreRunner SR5
    AFE CAI GIBSON SS cat back exhaust Throttle body spacer
    I've got a 2012 PreRunner and recently got a 20' camper. I've got a Prodigy P2 brake controller and a tow package in the truck. The trailer is about 3,800lbs fully loaded. I've taken two long trips (interstate 35 in TX ad OK) and other than slow pickup it tows fine between 60 and 65mph. I had a bad issue with sway on my last trip which got pretty scary. I'm having a weight distribution/sway control hitch installed. I'm also adding a CAI, throttle body spacer and performance exhaust installed to help with power.
  12. Sep 16, 2016 at 10:14 AM
    stump jumper
    Bill
    Texas
    Who was the snake oil salesman that sold you on the mods? I would like to know in case I meet him. You should always use a sway control set up on a TT regardless of size. The high profile catches wind. It may tow fine in light winds but not if you get a decent x wind.
    Ruggybuggy likes this.
  13. Sep 16, 2016 at 6:22 PM
    wsurunner
    Check your weight balance and rake of your trailer (don't want it to be super-light tongue or nose-up when towing), verify the trailer tires are properly aired up as well. They're no substitute for a WDH but these types of things can contribute to an unstable towing experience.
  14. Sep 16, 2016 at 7:21 PM
    Wmck
    Wmck Member
    Thanks .pressure is spot on. Will verify level before pulling next time
  15. Aug 11, 2017 at 11:51 AM
    Wmck
    Wmck Member
    not sure if anyone is following this but after the WDH I no longer have sway issues.
    I'm also getting about 20% better gas mileage and much faster acceleration with the CAI and exhaust modifications. I"ll see if I can send a note directly to the "snake oil" comment guy. I'm thrilled with the performance after the intake/exhaust mods
    SLeeper512 likes this.
  16. Aug 11, 2017 at 12:58 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Just curious here but I have heard to never tow with cruise control... is that not true?
  17. Aug 11, 2017 at 1:09 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    CC is fine - never tow in overdrive is the rule.
    And install a supercharger for a better towing experience.
  18. Aug 11, 2017 at 1:13 PM
    Harry
    Santa Fe NM
    :facepalm:
    Those mods will do nothing but add noise. That's 1/6 the cost of a supercharger right there.
  19. Aug 11, 2017 at 1:16 PM
    Toyko Joe
    Toyko Joe Here for the pictures
  20. Aug 11, 2017 at 1:30 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    For what you pay in a supercharger you could sell the truck and put the supercharger money into a f150
