Towing ? You must see this one weird trick doctors hate.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 127.0.0.1, Oct 4, 2016.
  1. Oct 6, 2016 at 5:50 PM
    #41
    bsktball55
    bsktball55 Active Member
    Years ago when I moved my now wife's crap over here I was pulling a 12ft uhaul trailer. I guess I didn't get it loaded correctly as I was hauling furniture and other stuff, but on the way home I kept getting the tail wag when semi trucks would pass me and their wind would be enough to move the trailer just a little and then the trailer started wagging my truck. There were no visual clues that it wasn't loaded correctly.
  2. Oct 7, 2016 at 4:12 AM
    #42
    127.0.0.1
    127.0.0.1 [OP] AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    no
    it depends where the weight is. period. more weight ahead of axle
    axle can be anywhere any normal legal trailer could attach them.
    weight can only be distributed a certain way to be safe, 10-15% more of the load on the tongue
  3. Oct 7, 2016 at 6:08 AM
    #43
    tgear.shead
    tgear.shead Well-Known Member
    Usually, you position the axle under the trailer such that the trailer will tow stable without ANY added weight.
    And we all know that the singular PURPOSE of a trailer is to carry THINGS, i.e. MORE WEIGHT.
  4. Oct 7, 2016 at 6:50 AM
    #44
    127.0.0.1
    /etc/hosts
    plz stop talking about axles in this thread
    why are people posting about positioning the axle ?
    no one this gif is aimed at, gets a trailer and moves the friggin axle.
    they get a trailer, and load it and off they go
    they may overload or misload it, then get squirrely on the highway and wreck
    anyone who has a trailer and moves the axle, it is not too far fetched to assume
    they know what they are doing, therefore do not need this gif to drive the point home
    TRDMountaineer, Torspd and CurtB like this.
  5. Oct 7, 2016 at 7:35 AM
    #45
    Pigpen
    Dan
    Northwest Montana
    / thread
    ChadsPride likes this.
  6. Oct 7, 2016 at 11:07 AM
    #46
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    You buy the trailer with the axle already positioned. This is a huge problem with the Harbor Freight trailers because the axle is at the half way mark. Many people who know what they are doing relocate the axle farther back
  7. Oct 7, 2016 at 11:25 AM
    #47
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What about boat trailers?
    Depending on the trailer you either move the axle or the winch assembly to achieve proper tongue weight.
  8. Oct 7, 2016 at 2:26 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hmm....I see a problem. Don't buy a Harbor Freight trailer.... seriously.
  9. Oct 11, 2016 at 6:23 AM
    #49
    tgear.shead
    You aren't using your head. I'm talking about MANUFACTURING the trailer, not using it.
    Torspd likes this.
  10. Oct 11, 2016 at 7:10 AM
    #50
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    This got out of hand rather quickly. Just tow within specification of vehicle. Then drive within specification of load. I.E. Don't be stupid. My uncle Ed always told me......"if your gonna be stupid, you gotta be tough"
    Torspd likes this.
