towing
Discussion in 'Towing' started by Eddyl57, Sep 18, 2018.
  1. Sep 18, 2018 at 5:04 PM
    Eddyl57
    Eddyl57 [OP] New Member
    2014 brown TRD
    looking for advice on towing !
  2. Sep 18, 2018 at 5:05 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    What are you driving?
    What are you towing?
  3. Sep 18, 2018 at 5:08 PM
    Eddyl57
    2014 brown TRD
    Just bought a2019 RV with a dry weight of 5109Lbs I know my truck will pull 6500 lbs and people at the rv place said it shouldn't be a problem ... looking for some feedback !!
  4. Sep 18, 2018 at 5:26 PM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
  5. Sep 19, 2018 at 9:48 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    People at the RV place said it wouldn’t be a problem because they wanted to sell you a trailer. It’s going to be a problem. When you load your trailer up you’ll be 5600 lbs or more. Your truck is rated to pull up to 6500 lbs and it will pull your trailer. But performance and gas mileage will be poor. Your truck will do ok on flat highways but on hilly and mountainous roads it’ll be a struggle. If you load your truck up with stuff and passengers you will likely be at or over the GVWR.
    I would get air bags and a WDH to help with vehicle ride and control. It’ll pull your trailer it’s just not the optimal vehicle to tow that much weight even though it is rated for 6500 lbs.
    TireFire likes this.
  6. Sep 19, 2018 at 11:17 AM
    Indy
    Indy Master of all I survey.
    Back truck to trailer, hitch up, drive away. You're TOWING!
    nobescare and RevivalOL like this.
  7. Sep 19, 2018 at 6:12 PM
    Pyritemica15
    Pyritemica15 Well-Known Member
    Norm
    2015 Pyrite Mica Tacoma double cab
    I have an RV similar size and have towed it a couple hundred miles both ways, kept it under 60 mph and under 2500 rpm's and it pulled just fine, have a Duramax also so not sure how often i will use the Tacoma to tow but was impressed how well it towed it.
  8. Sep 20, 2018 at 7:09 AM
    96carboard
    96carboard Well-Known Member
    Campers are very very large, and very light (weight) for their physical dimensions. That means that you will be fighting constantly with aerodynamics -- both in terms of wind resistance at any substantial speed, as well as being blown around by cross winds and the wake of any other large vehicle on the road that passes by (in either direction).
    When you are pulling something like this, the actual weight is only a very small part of the equation.
    My suggestion: Get a pop-up, or save the money and use motels instead.
  9. Sep 21, 2018 at 8:01 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    A option for better towing is to get the ovtune. It will give you more power for towing. The truck will put it fine. It may have some trouble pulling up steep hills.
