Towing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CRJH, Jun 28, 2021.
  1. Jun 28, 2021 at 10:08 PM
    CRJH
    CRJH [OP] 2018 TRD Sport 4x4
    C
    San Diego
    2018 Grey Tacoma TRD Sport
    ARE camper shell and Bed Slide
    How many of you tow with your Tacoma?
    I pull my 18ft travel trailer without a problem!
    Junkhead and AthensTac like this.
  2. Jun 28, 2021 at 10:12 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Nice! Glamis?
  3. Jun 28, 2021 at 10:13 PM
    CRJH
    C
    San Diego
    Gordon’s Well in this pic!
    TwinTaco31719 likes this.
  4. Jun 28, 2021 at 10:14 PM
    TwinTaco31719
    Eric
    Glenbrook, NV
    Awesome! I miss my glamis days growing up in Valley Center..
    CRJH[QUOTED][OP] likes this.
  5. Jun 28, 2021 at 10:17 PM
    tycorp
    tycorp Member
    2021 TRD Sport Premium Army Green LB DC
    I have a 194 bhs alex nano landing in 2 weeks
    CRJH[OP] likes this.
  6. Jun 28, 2021 at 10:37 PM
    Sloopythesloop
    Sloopythesloop Starboard!
    DFW
    2018 Tacoma TRD Off Road
    Brush Guard, Rock Sliders, lights, Topper, Add a Leaf, New Rear Bumper
    skiboat, sailboats and a camper with mine.
  7. Jun 28, 2021 at 11:21 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Have only taken this out for a spin to make sure brake controller worked, and it did...
    Was going to take it to the Grand Canyon last week but with all the fires decided not to.
    Look forward to cooler temps for sure.
    I suspect the Tacoma should have no problem with this thing... tips the scales at around 1,000 ~ 1,200 pounds depending.
  8. Jun 29, 2021 at 7:22 AM
    CRJH
    C
    San Diego
    You won’t have any issues with that, won’t even know it’s there!
  9. Jun 29, 2021 at 8:41 AM
    2021SR5V64WD
    There has been other discussions on this item, if ECT mode will do the trick or if I should also engage to S5. I guess I'll get a better
    feel for it when I actually take it out and hit some inclines.
    Lt. Dangle and CRJH[QUOTED][OP] like this.
  10. Jun 29, 2021 at 8:43 AM
    CRJH
    C
    San Diego
    I use a load leveling hitch with mine but it’s also about 4000lbs full loaded. It helps so much
  11. Jun 29, 2021 at 8:44 AM
    SpeySquatch
    2016 TRD OR DCSB
    Fully loaded with gear in bed about 4000-4300lbs. 4.88’s and OVtune help ALOT. 12-14mpg with this setup and 32’s
  12. Jun 29, 2021 at 8:45 AM
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    Towing my RPOD.
    2wd lo makes backing this thing up so much easier.
  13. Jun 29, 2021 at 8:48 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    gsubioguy and CRJH[OP] like this.
  14. Jun 29, 2021 at 8:48 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    I do but it's more utilitarian since Lynn's idea of camping is a Holiday Inn. :D
    RustyGreen and CRJH[OP] like this.
  15. Jun 29, 2021 at 8:49 AM
    Joe Joe
    Joe Joe Well-Known Member
    Arthurdale, West Virginia
    2019 White OR DC MT
    ADM 2Lo Mod 3TPAM
    It's not much but I'm usually pulling this trailer with 2 quads or a RT188 bass boat about every other weekend.
    TacoTrooper and CRJH[OP] like this.
  16. Jun 29, 2021 at 9:10 AM
    Taco1701
    Taco1701 Well-Known Member
    William
    GA
    2020 DCSB TRD Sport 4x4 Cement
    This is what I tow the most. The taco is perfect for something like this.
  17. Jun 29, 2021 at 9:13 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    My kinda gal....my idea of roughing it is a hotel without room service o_O
    One of the main reasons I got my Taco was to be able to tow my Honda Goldwing when I didn't have the time to ride it to where I was going. The Rav4 wasn't going to cut it for that. It will be on a UHaul 5x9 motorcycle trailer (can't see buying a utility trailer for 2-3 time a year of use). 1240 lbs empty plus another 900 lbs for the bike, no additional payload other than luggage and a helmet. Should be well within what the Tacoma can handle comfortably.
    Devious6[QUOTED] likes this.
  18. Jun 29, 2021 at 9:19 AM
    Illini Tacoma
    Illini Tacoma Well-Known Member
    2016 Dark Red Double Cab Short Box
    We pull our deck boat that weighs 3500 lbs. dry, around 4800 lbs. on the trailer. Our yearly mileage while towing is 1200 miles or less. The trailer is balanced perfectly thus the sag is negligible and we don't need WDH or air bags or Sumo Springs. I installed a TruCool 4490 trans. cooler. I am going to try pinning the trans. fluid thermostat open to see what effect that will have on our trans. temps. We pulled the boat without the cooler and I didn't see any excessive temps. (212° F was tops and it came down very quickly). Haven't pulled it very much since installing the TrueCool but it should run much cooler.
    The truck handles the boat remarkably well. I run in S4 with ECT engaged at all times. Our boat towing is confined to flat country and there is very little wind resistance to deal with. I can tow the boat 70 MPH without the Taco even breaking a sweat. So far we've been very impressed.
  19. Jun 29, 2021 at 9:35 AM
    CRJH
    C
    San Diego
    I’ll have to check out that trans cooler. It’s gets hot towing in and out of the desert. Multiple grades to climb.
  20. Jun 29, 2021 at 11:39 AM
    Illini Tacoma
    There are a bunch of different trans. coolers available. Not sure if there are any that are head and shoulders above the rest. I went with the TruCool since the physical dimensions and the fitting sizes were compatible with my installation. I've read that B&M coolers are exactly the same as TruCool. I don't know that to be a fact. Many have installed, and are quite happy with Hayden coolers. I've never really looked into a Hayden but I'm sure they will do the job as well as most all the rest.
