Towing!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rampage!67, Mar 6, 2022.
  1. Mar 6, 2022 at 11:40 AM
    Rampage!67
    Rampage!67 [OP] Member
    Cody
    2019 Toyota Tacoma TRD Off-road
    Hey guys. I'm in the market for a trailer. I got a 19 Tacoma 4 door short bed trd off-road. I've been finding these little toyhaulers. Dry 3000lbs and wet 7000lbs and was wondering what everyone was towing and what the opinions were
  2. Mar 6, 2022 at 11:42 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The truck likes 3K loads.
    The truck absolutely hates 6K loads.
    7K? Good luck with that.
    RustyGreen, Chew and Junkhead like this.
  3. Mar 6, 2022 at 11:45 AM
    Rampage!67
    Cody
    Yeah I agree tho I will say I've towed things just about as heavy on the ranch and it does better than expected. Just curious what my expectations should be cause I've seen people pulling crazy trailers with this little truck. I've got a dirt bike but it don't fit in my bed. I should've got the long bed lol
    hiPSI[QUOTED] likes this.
  4. Mar 6, 2022 at 11:49 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I've pulled 6.5K with it. After that, I traded for a Tundra. Now I do not have to tow those loads, I traded back to a Tacoma.
    I believe in the right tool for the job.
    I can take a 3/8ths ratchet with a 22mm socket and put a pipe on it to break 120 ft lb nut loose. Or, I can get an air impact to do the same.
    BillF1564 likes this.
  5. Mar 6, 2022 at 11:50 AM
    Rampage!67
    Cody
    Fair point. I want the new tundra. But I'ma wait it out for new generation issues lol
    Junkhead and hiPSI[QUOTED] like this.
  6. Mar 6, 2022 at 11:51 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I would too. Good luck man.
    Junkhead likes this.
  7. Mar 6, 2022 at 11:55 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The 3.5 is pretty gutless for towing but I also tow at 6000+ feet. Even after adding a supercharger it isn’t ideal but does get the job done without much complaint. I tow 3000lb boats a few times a month and after the supercharger the truck does fine other than poor fuel economy. I wouldn’t want to tow more than 5000lbs for any distance.
    hiPSI likes this.
  8. Mar 6, 2022 at 11:58 AM
    Rampage!67
    Cody
    I heard a tune helps out with the gutless part.
  9. Feb 13, 2025 at 11:28 AM
    cjbiii
    cjbiii New Member
    Chip
    2023 Tacoma SR-5 Double-Cab
    speakers, vent shades, bug deflector, tonneau cover
    The truck tows fine without a tune with the 3.5. Put the transmission in 5th or 6th gear by moving the shift lever to the left and up once or twice and push the ECT button when you start the truck. If you encounter a big hill, you'll need to be in rightmost lane. I was getting 13 MPG towing a clamshell trailer with 2 sleds in it and full of cargo most of the time. 6500 lbs is definitely pushing it though.
  10. Feb 13, 2025 at 11:38 AM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    a clamshell is a whole different game compared to a travel trailer. The wind drag on a travel trailer is not a fun towing experience,
  11. Feb 13, 2025 at 11:41 AM
    cjbiii
    cjbiii New Member
    Chip
    Makes sense. I also tow a 19 ft boat and that seems to work pretty well but I've never tried a travel trailer.
