Town Fair Tire says 16x8 wont fit!?!?!
Discussion in 'Wheels & Tires' started by Squaretail, Feb 20, 2012.
  1. Feb 20, 2012 at 1:20 PM
    Squaretail
    Squaretail [OP] Well-Known Member
    New Hampshire
    08 V6 Black Blurr
    So I just got back from Town Fair to price out some Duratracs and some new wheels.
    Wheels are probably going to be the Procomp 7089 with 285/75/16 duratracs.
    They said an aftermarket 16x8 wheel will not fit on a tacoma. They are not beveled out inside so they rub hardcore on the brakes. It seems like plenty of people here are running 16x8 with no wheel spacers.
    I wanted to run a 16x8, 0 offset, and 4.5 backspacing. The guy then told me that offset and backspacing were the same thing.
    Can someone please clarify this so I can go back there with more ammunition.
    My truck: 2008 extended cab 4x4, 3 in toytec lift
  2. Feb 20, 2012 at 2:22 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    So i just called Procomp. They said that issue with the calipers is two reasons: 1) different casting on different tacomas. 2) Free floating brake caliper: So with worn-out pads, it may fit, but def. won't fit with new brake pads.
    They recommended the 17x8, 4.5" BS, and 6 on 5.5 bolt pattern.
    Good FYI for you guys wanting to run aftermarket 16" wheels. In short, you cant do it.
  3. Feb 20, 2012 at 3:31 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Depends on the wheel brand. Many 16s fit fine, but some hit the caliper.
  4. Feb 20, 2012 at 4:09 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    KTP,
    Procomp says the 16x8 7089's will not fit...
    Do you know if the Moto Metal 951 or KMC enduro will fit with 16x8?
    Looking for a black wheel
  5. Feb 20, 2012 at 4:12 PM
    KPT
    09 Prerunner
    Yes, they will all fit, even the 7089. Plenty of people on here run them.
    I'm sure you can find some folks in our2nd gen builds section running them, to confirm.
  6. Feb 20, 2012 at 4:21 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You're doing the right thing asking around here. Townfair isn't the best source of information on wheel/tire info. They told me 265/70R17 wouldn't fit either. I got read the riot act on running a different tire size than what is recommended by the manufacturer... I'm not saying they're wrong, they're just a little over cautious sometimes.
  7. Feb 20, 2012 at 4:23 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I am running this set up. 0 off set 4.5 BS 16x8 Moto Metal 951. Everything fit just fine. Now it does seem to matter what wheel specifically. There is a thread on here where a guy bought 16x8's with the same specs and they rub the calipers. But if you want the Moto Metals I can vouch for them, I'm not running any spacers, just put them on about 3 weeks ago. I watched Discount Tire test fit them before mounting them also, which I had already done myself before I took them up there.
  8. Feb 20, 2012 at 4:26 PM
    TacoDawgfan
    Georgia
  9. Feb 20, 2012 at 4:27 PM
    TacomaChris
    TacomaChris Well-Known Member
    My 16x8 Enduros fit...but they're close
  10. Feb 20, 2012 at 4:41 PM
    Squaretail
    New Hampshire
    08 V6 Black Blurr
    I really want to go the 16" route because its a lot cheaper, but I talked to Procomp personally and they said the 7089 would not fit. I can understand townfair saying they won't fit because they want to make more money off bigger tires, but procomp manufacturers?
    Now I don't know which route to take.
  11. Feb 20, 2012 at 4:46 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    Running 16x8 in enduros and 6089s
  12. Feb 20, 2012 at 4:47 PM
    KPT
    09 Prerunner
    Like I already said there are plenty of people running the 7089s in 16". So procomp is incorrect, probably because they are owned by 4wp.
  13. Feb 20, 2012 at 5:00 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Are there conflicting specs here? 0 offset on an 8" wide wheel should equate to 4.0 backspacing, according to the diagram here: http://www.tacomaworld.com/forum/wheels-tires/102992-wheel-backspacing-offset-info.html
    Yes, I am fully aware 4WP shows the same specs: $99 Pro Comp Alloy Wheels Pro Comp Series 7089, 16x8 Wheel with 6 on 5.5 Bolt Pattern - Flat Black - 7089-6883 7089-6883 Pro Comp Xtreme Alloy Wheelshttp://www.4wheelparts.com/Wheels/S...s=210&t_pt=100073&t_pl=3635&t_pn=PXA7089-6883
  14. Feb 20, 2012 at 5:03 PM
    KPT
    09 Prerunner
    Backspacing and rim width are measured from slightly different spots. Backspacing is from the back edge of the wheel. Rim width is actually the distance between the bead seats. So if you go out and measure the wheels while they are on your truck, you will come up with close to 9" if your wheels are 8" wide.
    The diagram shows that, but it is subtle.
  15. Feb 20, 2012 at 5:06 PM
    KPT
    09 Prerunner
  16. Feb 20, 2012 at 5:10 PM
    KenLyns
    Belly of the Beast
    ^ Thanks.
  17. Feb 20, 2012 at 5:14 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    I had them test fit 16x8 Mickey Thompson Classic Locks in Black and they seemed to fit fine up on the jack, just another black option for you if you like the style. I'm almost positive theyre 4" bs, but i'm not sure about offset, i want to say the chart read -12 but i'm no pro on that sort of thing. . . I'll be pissed if they don't fit when i go for final install. . .
  18. Feb 20, 2012 at 5:20 PM
    jhodge83
    SC
    17 XLT Sport
    They're a 4" BS. Same as the pro comp 6089s.
  19. Feb 20, 2012 at 5:21 PM
    bskin
    bskin Well-Known Member
    Eagle River AK
    2016 DC TRD Off Road MT
    I'm running the procomp 7089's with no problems
  20. Feb 20, 2012 at 5:22 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Konig Countersteers are 16x8 and mine fit fine.
