Toy Tacoma trac off and engine lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by antonyall, May 18, 2017.
  1. May 18, 2017 at 3:32 PM
    antonyall
    antonyall [OP] Member
    Tony
    2014 Tacoma
    Help anyone. Started my 2014 this morning and the trac off light and engine check light on the instrument panel are illuminated and remain on as long as engine is running. When I shut down and restart they come on again and stay illuminated. Any suggestions as to cause or
    and repair....anyone???
  2. May 18, 2017 at 3:49 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Could be as simple as a loose gas cap (Evaporative Emissions Fault). Check the cap then disconnect the battery to reset. Could also be a speed sensor...
    Yager78 and antonyall[OP] like this.
  3. May 18, 2017 at 3:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    10 bucks says gas cap.
    antonyall[OP], tcjacado and EDDO like this.
  4. May 18, 2017 at 3:57 PM
    antonyall
    Tony
    2014 Tacoma
    Thanks Eddo. I did change the gas cap last weekend to a lockable type so will go down and apply your suggestion. Hope it fixes the problem and thanks much for your response.
    EDDO likes this.
  5. May 18, 2017 at 3:58 PM
    antonyall
    Tony
    2014 Tacoma
    Thanks nd4. Seems to apply but will check in a few minutes. Thanks again.
  6. May 18, 2017 at 4:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Take it to Auto Zone and get it scanned.
    Its gonna be a fuel cap issue or air injection pump and/or valves. Most likely the cap, though. The lockable ones can be pretty cheaply made. Put the original back on and disconnect the battery for a few seconds and reattach. The code will be cleared. Hopefully its the cap. The AIP repairs can be pretty spendy.
    antonyall[OP] likes this.
  7. May 18, 2017 at 4:34 PM
    antonyall
    Tony
    2014 Tacoma
    Just changed off my new lockable gascap for the old original one and disconnected the battery terminals for a minute and reconnected. Miss Trac Off light and Mr Checkengine light still illuminated. Will allow to stand for the night and then recheck in morning. This failing will move on to purchase a good analyzer/code reader as all cars nowadays are computerized.....what a lot of bull and a huge money grab that computers can be, Thanks koditten as well.
  8. May 18, 2017 at 4:38 PM
    koditten
    Kirk
    Central Michigan
    Hopefully it stays off. It takes a while for a bad gas cap to trip the check engine light. If you have no light after 2-3 days, you can be assured it was the cap.
  9. May 18, 2017 at 4:48 PM
    antonyall
    Tony
    2014 Tacoma
    I just hope that this is the problem as just going to Toyota will cost $200 for the assessment plus parts or such. In any event it appears that I will not be able to use that lockable gascap anymore and am stuck with it so $25 Canadian dollars wasted. Just hoping that it is not a more major problem as quite coincidental that it illuminated just after I changed gascaps. Hoping here and thanks again! At least computers do have some good uses huh!
  10. May 18, 2017 at 5:12 PM
    koditten
    Kirk
    Central Michigan
    No problem.
    don't be a stranger. Check in on a regular basis. This place can be pretty fun when you are bored out of your mind. Some pretty smart guys and gals hang out here pretty regular.
    Oh, and welcome to the show.
    Plain Jane Taco likes this.
  11. May 18, 2017 at 5:17 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    We're here if you need us.
    MotoEd and koditten[QUOTED] like this.
  12. May 18, 2017 at 10:23 PM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
    Damn your head is looking like your rear end. Shiny and smooth.
  13. May 18, 2017 at 10:25 PM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
  14. May 18, 2017 at 10:30 PM
    tcjacado
    tcjacado Well-Known Member
    It is most likely that new gas cap. I had the same happen with my 3rd Gen. I disconnected battery for 15 minutes and then restarted and all lights gone. Glwr
  15. May 18, 2017 at 11:32 PM
    JD_P
    JD_P Well-Known Member
    Terrebonne, Oregon
    2015 TRD Off Road Access Cab
    I had the same thing happen with a locking gas cap. Ended up going back to OEM. I have an ultragauge, so I was able to reset the code. Have heard others have had similar issues with aftermarket caps. CEL will come on initially, then after a while the trac off light. Something to do with emissions.
    tcjacado likes this.
  16. May 19, 2017 at 6:40 AM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Just for future reference, when the MIL (check engine lamp) comes on, the VSC, Trac and/or ABS lamps will illuminate as well. The PCM just disables those systems (fail safe) until the cause of the MIL is corrected. Usually a code of C1201 will be stored, no troubleshooting should be done with the C1201 until the MIL is cleared.
  17. May 19, 2017 at 8:35 AM
    antonyall
    Tony
    2014 Tacoma
    Thanks for the assistance JD. Have not gone out as yet but thanks.
  18. May 19, 2017 at 8:36 AM
    antonyall
    Tony
    2014 Tacoma
    Thanks Jeff and am just hoping it is the gascap as don't want to spend unnecessary money at the moment.
  19. May 19, 2017 at 8:37 AM
    antonyall
    Tony
    2014 Tacoma
    Actually I will go down and disconnect the battery for a few more minutes and try again. Thanks JaCabo
    tcjacado[QUOTED] likes this.
  20. May 19, 2017 at 8:38 AM
    antonyall
    Tony
    2014 Tacoma
    Thanks for the welcome Plain Jane Taco!
