Toyo AT II P285/70/17
Discussion in 'Wheels & Tires' started by 09 Redneck, Feb 13, 2013.
  1. Feb 13, 2013 at 5:33 PM
    09 Redneck
    09 Redneck [OP] Well-Known Member
    Ga
    Thinking about stepping up to P285/70/17 Toyo AT IIs. Right now I have P265/70/17 Toyo ATs. Is anybody running this size tire in a "P" range? They only weigh 7 more pounds so do you think it will affect my MPG that much? I drive about 100 miles a day for work. I already have OME 885s up front. Any thoughts on this? Thanks....
    P265/70R17 113S 352000 7.0-8.0-9.0 41 13 31.5 10.7 14.2 2535 44 600 A B 659 2P+2S+1N 2P
    P285/70R17 117T 352150 7.5-8.5-9.5 48 13 32.8 11.5 14.6 2833 44 600 A B 634 2P+2S+1N 2P
  2. Mar 1, 2013 at 5:06 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    With only 7lbs difference you should be ok. If you get these check out treaddepot.com as they seen to have some of the cheapest prices on these.
    MGMTaco17 likes this.
  3. Apr 18, 2013 at 1:16 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Did you get these tires? Id like to know how they are. I have been doing my homework and am stepping away from MTs into ATs now. I had Toyo OCs on my rig when I bought it and didn't care for the tire. I have Nitto Grapplers now that are chunking horribly. I hear the Toyo AT II is a whole new animal. It has an awesome warranty of 65,000 miles and a huge amount of tread. What is your experience with them?
    Thanks
  4. Apr 18, 2013 at 3:29 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I've got the Toyo AT II's in 285/70/17. I've only had them for 2 weeks but so far so good, they look good & ride pretty smooth. They have a slight hum but nothing like a MT. As far as mpg's I haven't noticed any difference, last week I used the same amount of gas for the week as I did with the stock 265's.
  5. Apr 18, 2013 at 6:18 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    I dont have Toyos but I run the 285 Dueler revo 2s in the P rated and they are 46lbs and i still get decent mileage. Better then my 265 BFgoodrich TKOs actually
  6. Apr 18, 2013 at 6:21 PM
    09 Redneck
    Ga
    Yes and no. I got the tires but stayed with 265/70/17s. So far have about 7500 miles on them and they ride great. No problems,balance well just a little hum. I wanted the 285s but with driving 100+ miles a day I stayed with the 265s. The set I took off I got almost 65000 and never had a problem with them either.
  7. Apr 18, 2013 at 8:00 PM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Thanks, im going with a 285x75r17, been running a 295x70r17 for 2 years on my rig. Im doing a full overhaul on my pro comp 6" lift. In fact there will only be a pro comp crossmember when im completed so I have the room for the tires. I haven't read anything bad and with that warranty I can get toyo to replace them if they start chunking bad. Temp and terrain here in Phoenix is hard on tires both on & off road.
  8. Apr 19, 2013 at 12:22 AM
    BORNWILDGUY
    Rich
    Florida
    Try treaddepot.com when your ready to get them. I have found they have about the best prices on them.
  9. Apr 19, 2013 at 8:12 AM
    2ndGenJonny
    Jon
    Gilbert, AZ
    Thanks for the advice! I looked at the prices there and you aren't kidding about cheap!!!! :thumbsup:
    I'm going to use the guys at SDHQ for all of my upcoming upgrades. They are a Toyo dealer, I will see if I can get those prices matched as I will be spending about 5G.
  10. Nov 21, 2013 at 3:31 PM
    Postmasteroats
    Postmasteroats Well-Known Member
    NW Minnesota
    2007 4x4DC 6 TRD sport
    I had AT and got 50,000 with more to go but winter was coming. Put on AT11 and the ride is much better and they are also quieter. $180.00 mounted and balanced for 265/70/17.
  11. Jun 12, 2015 at 10:39 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    Haha I know it's been 2 years but just curious were you running LTs or Ps? And what did you keep your tire pressure at? Thanks.
  12. Jun 12, 2015 at 10:56 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Haha yeah its been a while, I was running the P's & kept the pressure at like 30. I have since switched to 35" MT's
  13. Jun 12, 2015 at 10:59 AM
    Alfred
    Alfred
    California
    Thanks bud!
  14. Jun 12, 2015 at 11:00 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    if you off road at all word to the wise do not get P rated off road tires if you do not off road at all then P rated All the way
  15. Jun 12, 2015 at 11:02 AM
    Alfred
    Alfred
    California
    I have the LT285/70/17 and I've been trying to figure out a great tire pressure to run them at. Right now I have them at 50psi I believe.
  16. Jun 12, 2015 at 11:23 AM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    im not sure man, i have lt265/75r16 bfg ko2's load E and i run them at 36psi all the way around. Rides nice.
  17. Jun 12, 2015 at 12:20 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    No problem.
  18. Jun 25, 2015 at 8:50 PM
    Taco Mark86
    Taco Mark86 Well-Known Member
    Mark
    NC
    09 DCSB with some mods
    Magnaflow, Fox RR/ Camburg UCA up front, Bilsten 5100 and some kind of AAL/ leaf pack in the back?, Light bar w/ Hella, and an air freshener
    do the 285/70r17s come in the Xtreme tread? Anyone have pics of this tire and size on the truck? I'd love to see em
  19. Jun 25, 2015 at 10:42 PM
    Alfred
    Alfred
    California
    Heres the at2 in LT285/70/17. I don't think they make the xtremes in that size. These are LT tires not the P rated. I believe the p rated are less aggressive looking.
    But these LTs are pretty aggressive in person.
    MGMTaco17 and whelm like this.
