Toyo AT2, 265/75 R16, C Load - PSI??
Discussion in 'Wheels & Tires' started by Mr_Stagger_Lee, Apr 28, 2019.
  1. Apr 28, 2019 at 6:40 PM
    Mr_Stagger_Lee
    Mr_Stagger_Lee [OP] Active Member
    Hey folks, does anyone know the correct PSI for C-Load, Toyo AT2 265/75 R16s? I have a 2017 Off Road.
  2. Apr 28, 2019 at 6:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Unloaded 28-32 psi cold, run a chalk test.
    Depending on trailer or bed load, I would go as high as 40psi on rears.
    Paul631 and Mr_Stagger_Lee[OP] like this.
  3. Apr 28, 2019 at 6:45 PM
    ClemsonMGM
    ClemsonMGM Even Firemen Need Heroes...
    Workin the pole!
    12 Ram 2500
    I run mine at 34.
  4. Apr 28, 2019 at 6:49 PM
    Mr_Stagger_Lee
    That sounds like a good pressure. How is your tire wear from that psi?
  5. Apr 28, 2019 at 6:50 PM
    Mr_Stagger_Lee
    And how about yours Bishop84, how is your tire wear at those psi's? Really digging these new tires BTW. Looking forward to testing them off road in a week.
  6. Apr 28, 2019 at 6:53 PM
    Bishop84
    Don't have them anymore but I know lots of guys and customers with AT2's and they wear great, best of all the all terrains, we run lower in Canada due to weather. But you want shoulder wear to help with reducing noise. Best way to do so is to have lower pressure.
    Also with any all terrain remember to rotate cross diagonal, this helps keep them quiet and healthy for years.
    I'm thinking about getting the 4 season version of the AT2's soon for my Xterra
  7. Apr 28, 2019 at 7:00 PM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    I put them on at 36k. At 83k now and still could go another 10k I believe. Rotated every oil change.
  8. Apr 28, 2019 at 7:11 PM
    Mr_Stagger_Lee
    Awesome! Thanks for the feedback you guys! I'll try both pressures out and go from there.
  9. Apr 29, 2019 at 9:26 AM
    Mr_Stagger_Lee
    Forgot to ask both of you -- Im testing my tires on some trails soon, how low were you able to air down?
  10. Apr 29, 2019 at 10:19 AM
    ClemsonMGM
    Workin the pole!
    12 Ram 2500
    Never aired mine down. I don’t do a lot of off roading
  11. Apr 29, 2019 at 10:21 AM
    Onwarrds
    Onwarrds @onwrrds
    Tyler
    Southern California
    2017 Black TRD OR 4x4 DCLB
    Fox 2.5 DSC Adjusters (Extended Travel), Camburg UCA, RCI Rear Bumper, Cali-Raised Zero Degree Step Rock Sliders (with filler plates), Softopper, TRD Pro Skid, Rigid, Baja and KC lights, H9 Headlight Upgrade.
    I run all 4 of mine at 36-40 cold psi. They ride great on the highway with very little bounce. Off road I air down to about 16-20psi. Great tires!
    Mr_Stagger_Lee[OP] likes this.
  12. Apr 29, 2019 at 5:10 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Same size & load rating on mine, I run 32F, 27R cold. This is for a unloaded bed, and lightly loaded cab.
  13. Apr 29, 2019 at 8:33 PM
    glazer1972
    glazer1972 Well-Known Member
    05 Tacoma PreRunner Double Cab 4.0L
    Intermittent Wipers.
    32-35psi
  14. May 4, 2019 at 5:34 PM
    Lunchmeat79
    Lunchmeat79 Well-Known Member
    Kansas
    '18 Off Road
    I wish they sold that version down here! I even called Toyo corporate. They said no plans to bring them to the USA.
  15. May 5, 2019 at 5:27 PM
    Mr_Stagger_Lee
    Really digging these tires. Aggressive, quiet and not too heavy. Really happy with my purchase. Thanks for the feedback folks!
  16. Jul 13, 2023 at 12:16 PM
    Jchase73
    Jchase73 Member
    2002 tacoma4x4
    3in lift goodwrench allterrain
    Ok got new ball joints and cv joints getting new toyos 265-75-16 tom wheres a good place in florida to test these out?
