Toyo AT3 SL good for off roading? E load is too much?
Discussion in 'Wheels & Tires' started by OlgaTheOgre, Sep 14, 2022.
  1. Sep 14, 2022 at 8:03 PM
    OlgaTheOgre
    OlgaTheOgre [OP] Member
    Alex
    2nd Gen 4 Banger
    Bilstein 5100 Front Toyotec Rear Old Man Emu Heavy Duty Rear Leaf Springs Sleeping platform / Curtains / Cheap storage system Beefier tires and Pro Comp Rims
    Hey,
    Maybe this has been asked but I want some toyo at3 but in 265/75r16 and they only have e or SL rated.
    From everything I’ve read, e will be too stiff. I drive a 4 banger. Will SL handle or do I go with a different tire?
  2. Sep 15, 2022 at 8:29 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    In my opinion, suspension and tire pressure make more of a difference than load rating. If you offroad at all, I'd go with the E load and play around with tire pressure/chalk test them.
    Mark77 likes this.
  3. Sep 15, 2022 at 8:41 AM
    eurowner
    eurowner Duke Sky
    Scoty
    No problems with my SL rated 265-75-17 Toyo Open Country ATIII off-roading. Nor did I have any problems with the SLL rated 265-75-16 ATII.
    02Duck and OlgaTheOgre[OP] like this.
  4. Sep 15, 2022 at 9:22 AM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    I have the SL rated 265/70/r17. We did our Utah/Arizona trip on them including Parashant and a few other places where 'bring two spares' is recommended. Had no issues and required no spares. Since then they have done just fine on all the random forest service roads and weird offshoots. I don't go hard, heck I'm not sure I even know what going hard means, so SL works great for me. I'm glad I went SL and I'd do it again. Maybe you go harder or have worse luck than me, just have your spare in working condition and if it becomes a pattern go heavier then.
    Only downside is I keep getting asked by my offroading friends if I'm getting new tires soon (10k on them right now) because the SL sidewalls and AT tread pattern are not very deep or aggressive looking.
    OlgaTheOgre[OP] likes this.
  5. Sep 15, 2022 at 3:14 PM
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    Since OP has the 2.7L 4 cylinder I believe the extra weight of the E will negatively impact his truck’s overall drivability.
    18CHUÑO, JNG, eurowner and 1 other person like this.
  6. Sep 15, 2022 at 3:57 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    There are really only 2 situations that we recommend going up to a higher load range, in most cases from the SL to the E load.
    1: If you are often towing near or at the max vehicle load capacity a 10ply tire will run cooler and will likely last longer as well handle the towing better.
    2: If you're offroading in areas where there are sharp obstacles, a heavier tire construction can help prevent punctures due to the changes made to the carcass that increases load capacity.
    ~Doug
    Please feel free to leave any feedback for our forum team by following the link below!
    Give us feedback
    Forum Hours
    Mon - Fri: 9 AM to 6 PM (ET)
    Sat: Offline
    Sun: Offline
  7. Sep 15, 2022 at 4:14 PM
    scocar
    scocar hypotenoper
    OP don't get Es unless you are offloading A LOT. I got some Cooper ST Maxx Es, and for daily driving, and towing, they will slow your acceleration, increase braking input, and require relentless rotation and balances. I have a 2015 DCLB V6, with a Leer RCC (heavy), and carry a full size spare. And I tow a 1800 lb trailer and a full bed of camp gear in mountains.
    I sold those Coopers and got some Falken Wildpeaks, roughly load. C, and have no regrets at all. Drivability improved, and the did fine on the rocky approach section to the start of the Rubicon Trail no issues, great traction off and on road, and rain.
  8. Sep 15, 2022 at 4:25 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Sounds like crappy tires/alignment if they need constant rotation and balancing. I went through a whole set of tires (55k miles) without ever rebalancing or even rotating, with tearing chunks of tread off from wheeling.
  9. Sep 19, 2022 at 2:57 PM
    OlgaTheOgre
    Alex
    2nd Gen 4 Banger
    That's what I was thinking, any extra rotating mass and I'm sure it won't be great.
    18CHUÑO likes this.
  10. Sep 19, 2022 at 3:00 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    The people on here whining about E rated tires riding rough never owned a truck and came from driving a bmw.
    Get the E's.
    TacoTimNL likes this.
  11. Sep 19, 2022 at 3:15 PM
    18CHUÑO
    18CHUÑO Well-Known Member
    Antoine
    2016 Tacoma SR5 i4 AC 4x4 Super White
    If ur at any sort of elevation, stick with SL on the 4banger
  12. Sep 19, 2022 at 3:16 PM
    OlgaTheOgre
    Alex
    2nd Gen 4 Banger
    I'm in SLC and ride up to 10k regularly, I'm currently running the Humko Adventure 51's and they're P rated and do everything so I'm leaning SL.
  13. Sep 19, 2022 at 3:21 PM
    18CHUÑO
    Antoine
    People reccomending E rated tires on a i4 gen 3 have never off roaded in one lmao
  14. Sep 19, 2022 at 3:21 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I’m not a hard wheeler. That said, I would only choose an E if it was the only option in a specific size I want. If SL is available, I’m getting SL. Especially on a 4 banger.
    18CHUÑO likes this.
  15. Sep 19, 2022 at 3:25 PM
    OlgaTheOgre
    Alex
    2nd Gen 4 Banger
    Lol yeah, it's not the rough ride I'm worried about, it's the...getting up the hill. Add on a SO and 2 dogs and all of our gear, those extra 6lbs per corner adds up.
    18CHUÑO[QUOTED] likes this.
  16. Sep 19, 2022 at 3:26 PM
    18CHUÑO
    Antoine
    100000%
  17. Sep 20, 2022 at 10:02 AM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    I have these in 265/75r16 SL, air down and be mindful of what line you choose and what you go over or around and you should be fine.
    I've gone through tons of sharp rocks and shale, forestry trails with fallen cut trees (ground spears), rivers, mud, snow/ice etc without problems. I know guys with E rated tires that have blown their tires or cut side walls but mostly because they are overloaded and not aired down.
    18CHUÑO likes this.
  18. Sep 20, 2022 at 11:40 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I had good luck with my SL rated Wildpeaks. Even over some rocky terrain (albeit not super sharp rocks). I wouldn't hesitate to run them again. But, it's also smart to make sure you have a capable, full size spare and the tools / repair materials needed for trail repairs. If you are constantly going hard and often in areas far from any service or help then I could see the E rating as an extra layer of confidence.
  19. Sep 30, 2022 at 11:18 AM
    OlgaTheOgre
    Alex
    2nd Gen 4 Banger
    Thanks for all the advice! I ended up going with the Toyo AT3 SL and took them out to a reservoir this weekend, they're awesome! Quiet on the road but gravel road grip is great.
  20. Sep 30, 2022 at 11:36 AM
    plim11
    plim11 Active Member
    California
    2019 tacoma trd offroad 4x4
    Been using toyo at3 sl 285/70r17
    No issues offroading
