Toyo OC AT3s E vs SL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rasfetch, Sep 26, 2023.
  1. Sep 26, 2023 at 5:38 PM
    Rasfetch
    Rasfetch [OP] Member
    Hey guys - shredded the sidewall on one of my stock Tacoma tires on a desert hunting trip. I was already planning on replacing them before this winter anyways so not a big deal.
    I'm planning on going with the Toyo Open Country AT3s in 265/75/16. I've seen plenty of threads about them but not much comparing the E to the SLs.
    I love the highway performance of the stock Goodyear Wrangler tires but I've had multiple flats in them and do quite a bit of offroad driving on rocky desert and mountain roads. This has me leaning towards an E rated tire in the Toyos. That said, if the Toyo SLs are quite a bit heavier duty than the Goodyear Wrangler SLs, I'm wondering if they'd be tough enough for my uses.
    Would you recommend the SLs or the Es for my uses?
    Also, thoughts on buying 5 Toyos or buying 4 and keeping my lightly used Wrangler spare as my spare?
  2. Sep 26, 2023 at 5:59 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    ATIIIs are great quality and super versatile. Just be advised they are loud on pavement especially in the E load rating.
    Duratracs for example are quieter but from my experience aren't as good in rain as the ATIIIs.
    I can't speak on sidewall strength of the ATIIIs tho..hopefully others will chime in
  3. Sep 26, 2023 at 7:34 PM
    Rasfetch
    Thanks for the insight. Right now I'm leaning towards dealing with the pavement noise to have the additional protection & capability offroad that the E offers.
    LeakyAC likes this.
  4. Sep 26, 2023 at 7:44 PM
    Bishop84
    Bishop84 Well-Known Member
    I run E's so I dont stress every time I smash into a rock, I bomb along back roads nearly every day.
    E's last longer, more tread, thicker, there's a lot of pros to the cons.
  5. Sep 26, 2023 at 7:59 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I would say go with E rated tires if you already blew out a sidewall on one of your current tires.
    I have E rated 265/75/16 tires on my truck which is also my DD and I will only buy E rated tires going forward. I haven’t had any issues with the road noise or quality (except for some uneven wear, which has nothing to do with the load rating).
    I highly recommend E rated tires.
  6. Sep 26, 2023 at 11:05 PM
    squamishdroc
    squamishdroc Well-Known Member
    Powell Riveria
    2021 Off Road Premium in AG
    5100's and Cooper 265/75/16's
    E rated all the way - the stock tires on my truck lasted one week before a rock put itself through the tread of one tire.
  7. Sep 26, 2023 at 11:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    For your situation, E’s. The only real downside is the weight and the extra stiffness.
  8. Sep 27, 2023 at 2:57 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I runt the SL in a 285/70/17 AT3. Its a great tire, light, easy ro balance, 50k mile warranty and the SLs are super quiet on the highway. I made the switch years ago from BFGs and been on many SL rated Toyos in the AT2s which are awesome until the 3s came out. My family runs them on their Tacomas.
    Rasfetch[OP] and nl_tacoma like this.
  9. Sep 27, 2023 at 6:37 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    If you are going places that lead to punctures in light-duty tires, then getting “E” rated replacement s seems warranted.
    We’ve opted for E rated spares in our Tacos; although both are used singles. Again, if you are somewhere that flattened an E, an SL or P might not be suitable to get you home.
    Junkhead and Rasfetch[OP] like this.
  10. Sep 27, 2023 at 6:51 AM
    Rasfetch
    Thanks, that's about what I've been thinking too. Do you do a 5 tire rotation to rotate the spare in or just leave it below?
  11. Sep 27, 2023 at 7:41 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    They have them in C-rated too. A decent in-between. I personally won't go back to an SL-rated tired.
    Canadian Caber likes this.
  12. Sep 27, 2023 at 11:01 AM
    smallfrye
    smallfrye Well-Known Member
    Stock
    I'm on my 2nd set of SL's and didn't have any issues with them offroad.
  13. Sep 27, 2023 at 9:44 PM
    BC Hunter
    The spares on both trucks are non-identical and on steel wheels, so no 5-tire rotation.
    One is the “best” winter tire from a previous set, which matches the new winters and is “close enough “ to the new summers….and the other is a new 235/85/16 winter “E” rated to be a spare for a set of 265/75/16s.
