toyo open country 285/65r18
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Venom-T, Apr 17, 2020.
  1. Apr 17, 2020 at 9:49 PM
    Venom-T
    Venom-T [OP] New Member
    Atabay
    2015 Tacoma TRD Sport
    Hi Tacoma family.
    I have 2015 tacoma sport with toyo open country 285/65r18 tires. I was wondering if anyone knows what tire pressure psi I need ?
  2. Apr 18, 2020 at 9:16 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Unless the weight of the truck has changed.
    The pressure listed on the sticker located on the door frame should be fine.
    Larger tires need more air. But not necessarily more pressure.
    It is far more complicated to find the correct psi.
    The “easiest” way to get a base PSI is to do Chalk Test.
    This is not always “correct”. But it should get you close.
    https://www.jlwranglerforums.com/fo...ould-i-run-do-a-chalk-test-to-determine.4622/
    FWIW, I run 32 psi in all mine all the time. Maybe ~35 in the rear if I’m hauling a lot of weight.
