Toyo Open Country AT3- Sidebiters
Discussion in 'Wheels & Tires' started by .Q., Jan 17, 2025.
  1. Jan 17, 2025 at 2:03 PM
    .Q.
    .Q. [OP] Well-Known Member
    Stowe, VT
    2013 Tacoma DCLB TRD Sport 4x4
    Hi all,
    After lots of research I am pretty certain to be going with the Toyo Open Country AT3 as my next tire.
    Going to get the LT265/70/R17 in load range E (needed for my camper).
    Unfortunately, no shop in my area has these tires in stock for me to look at.
    I am wondering how aggressive the sidebiters are on this specific tire size & load rating??
    The sidebiters on the floatation range of these tires looks nice (fairly aggressive but nothing too crazy) while the sidebiters on the LT range of these tires looks almost non-existent (not aggressive, very flat).
    However, I think I read here on the forums that the sidebiters on the LT265/70/R17 (and sizes up from there) are the more aggressive sidebiters, which I certainly hope is true.
    I even called and spoke to Toyo but the representative couldn't confirm either way (strange).
    Does anyone have the AT3 in LT265/70/R17 load range E that could confirm how aggressive the sidebiters are??
    If you happen to have pictures that you could post I would be very appreciative.
    Thanks!!
    Finn-2187 likes this.
  2. Jan 17, 2025 at 2:06 PM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I have the SL version of this tire and can at least confirm they have no real side biters at all. To your actual question, I've always read like you say that the E loads have the aggressive side biters.
    RealTruck likes this.
  3. Jan 17, 2025 at 4:24 PM
    .Q.
    Stowe, VT
    Thanks for the reply!!
    Good to hear you also read the E rated tires have the more aggressive sidewalls
    Finn-2187[QUOTED] likes this.
  4. Jan 17, 2025 at 4:28 PM
    .Q.
    Stowe, VT
    In reading the big Toyo AT3 thread, some posts indicated that the USA made tires had much thicker sidewalls then the Japan made tires.
    Those posts were back in 2020 though.
    There was even a post with Toyo confirming this (post # 492).
    USA made, thicker sidewalls, a little heavier vs Japan made, thinner sidewalls, a little lighter.
    Anyone know if that still holds true??
  5. Jan 17, 2025 at 8:40 PM
    Road Bull
    Road Bull Well-Known Member
    WA
    2022 Tacoma TRD OR; 2002 4Runner
    The LT’s have the more noticeable side biters. If you want a more aggressive side biters, look at Mickey Thompson AT’s. The Toyo AT3’s are light for what they are. But they are less exciting than some other options. IMG_1899.jpg IMG_1838.jpg IMG_1886.jpg
  6. Jan 18, 2025 at 4:11 PM
    .Q.
    Stowe, VT
    Your tires look good. What size and load rating are they?? Do you happen to know where they were made (usa or japan) or what is the plant code is on the tires??
    The Mickeys are great and I researched them but they are really heavy.
    The light weight of the Toyo's is a major reason why I chose them. I wanted a lighter AT tire with less rotational weight to help counter the weight of the camper. But also trying to ensure I can get the at3 with the most aggressive sidewall as well.
    Road Bull[QUOTED] likes this.
  7. Jan 18, 2025 at 5:15 PM
    Road Bull
    WA
    Thanks, they are 285/75/17" (34") E load rating, made in the U.S. I got them from Discount Tire a little over a year ago and they are wearing evenly and hardley look as if they lost much tread at all. If weight high importance, you will be hard pressed to select a lighter option in its class.
  8. Jan 19, 2025 at 11:05 AM
    .Q.
    Stowe, VT
    Perfect, thanks so much for the reply and info!!
