Toyo Open Country AT3 vs Falken Wildpeak AT3W
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baltimorebirds2, Jun 19, 2022.
  1. Jun 20, 2022 at 8:32 AM
    #41
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    I run 37 psi cold in mine and have been perfect.
  2. Jun 20, 2022 at 8:44 AM
    #42
    Dawelda
    Dawelda Well-Known Member
    West of West Phoenix
    20 Tacoma DCLB TRDOR Desert Sand
    2.5" lift w/33" tires, 10K Winch & bumper, camper shell
    Look up "chalk test for tire pressure" on Google or here in TW. Someone provided it for me and I found it helpful. :cheers:
  3. Jun 20, 2022 at 9:19 AM
    #43
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    At this point I would avoid peaks. They used to be a good deal a few years back but now they are the same price as more premium tires.
    In less than 2 years mine are already dry rotted and were a bitch to balance. They still shake to this day.
  4. Jun 20, 2022 at 9:20 AM
    #44
    fourfourone
    100% agree.
  5. Jun 20, 2022 at 9:36 AM
    #45
    redeyehal
    redeyehal Well-Known Member
    South East USA
    2020 TRD OR
    PTR57-35170 TRD Pro Shift Knob PT857-35200 LED Bed Lighting Kit PTR03-35160 Tacoma TRD Performance Air Intake PT84K-35221 TRD Lift Kit PT27835170 Roof Rack - Double Cab
    Beautiful truck.
  6. Jun 20, 2022 at 12:51 PM
    #46
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I can't add a whole lot to this discussion, but I had Falkens (265/70R17 SL 115T) and I absolutely hated them. They immediately felt really heavy for an SL, they scrubbed the concrete very aggressively on turns and made the steering feel really loaded down, they definitely hit my mpg by at least 3 on the highway and the tire shop could not get them to balance right. That was coming from 265/75R16 Hankook ATMs that I was not real fond of either. I had Discount swap the Falkens to General Grabber ATX 265/70R17 SL and instantly all my complaints from the Falkens were alleviated. I will say the Falkens did have very good wet and dry traction, but then again so did the ATX.
    As said by others, the Falkens were originally a budget tire and were priced accordingly. apparently the traction for the price won people over because they all decided to run them, and natural supply and demand ran that price up to now be about the same as the most expensive tires, or at least close. Certainly more expensive than other better tires. So I would say the Falkens are never worth it, based on my experience and the now current price.
    On my Tacoma I am looking to try the Toyo ATIIIs. Currently have BFG KO2 265/70R17 Load E, and am not a fan. Am hoping whatever I get by downsizing back to 265/65R17 will give me some power, mpg, and overall lighter weight back. I'm about to read through this thread and see what the opinions on Toyos are.
    Edit: read thread, looks like plenty agree with me and like the Toyos. I think I am finally sold on the Toyos now.
  7. Jun 20, 2022 at 1:00 PM
    #47
    xndak
    xndak Well-Known Member
    2023 Off Road
    Had the Falkens for 40k - Excellent tire all around except for they liked to slip initially on ice and snow. Have the Toyo now and it has much better initial bite probably due to the extra siping. Both are really decent on the road as well.
    musicisevil likes this.
  8. Jun 20, 2022 at 1:19 PM
    #48
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    I've been running the 265/65R17 XL Toyo ATIII's for over a year and they've been absolutely rock solid on my truck. They are quiet (almost to the point that my original Toyo A 30 HT's were). They are excellent on pavement both dry and wet and track true. I do a lot of mudding and they are quite impressive so far.
    geo8866 and BLtheP[QUOTED] like this.
  9. Jun 20, 2022 at 1:32 PM
    #49
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Disagree . We had a significant snow 2 years in the row and WPs performed as expected.
  10. Jun 20, 2022 at 1:35 PM
    #50
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Strange, my 255/80/17 wildpeaks required very little weight to balance. They are smooth as glass at any speed.
    Tocamo and baltimorebirds2[OP] like this.
  11. Jun 20, 2022 at 1:36 PM
    #51
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yep, 35 is about right. Unless you run heavy.
  12. Jun 20, 2022 at 4:14 PM
    #52
    eurowner
    eurowner Duke Sky
    Scoty
    Do you perform the chalk test when the tires are cold or hot?
    baltimorebirds2[OP] likes this.
  13. Jun 20, 2022 at 4:22 PM
    #53
    Dawelda
  14. Jun 20, 2022 at 4:26 PM
    #54
    eurowner
    eurowner Duke Sky
    Scoty
    What I do /\
  15. Jun 20, 2022 at 5:17 PM
    #55
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I guess you just got some from a good batch. I’ve seen other threads around here about balancing issues with WPs, and then there are many who say theirs had no problem like yours (which is why I figured I’d give them a shot). I’m sure this can happen with any brand of tires, but when it happens to me, I’ll avoid that brand like the plague in the future. In 30 years of driving, these tires have caused me more grief than any other tires I’ve had.
  16. Jun 20, 2022 at 7:04 PM
    #56
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Respect
    Layne is a big influence and a greatly missed talent.
    On topic, I've been runnin Falkens for almost 2 years now, i really dig em, haven't had any issues.
  17. Jun 21, 2022 at 1:47 AM
    #57
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I have always had a 4wd of some sort, ran BFG AT and not anymore. Made the switch to Toyos AT2s in 2018 on my new Tacoma. I have 20K miles on my Tacoma and the Toyos are awesome, light, easy to balance with little weight,quiet, great on the beach,in the rain. Never been in deep mud or snow. They are simply the best I have had so far, nothing bad to say about the WP but read alot about balancing issues and heavy. Now onto the Toyos AT3s are imo simply the best. I don't have a set yet but my Son's truck is identical to mine, same lift,wheels,suspension,every mod I have we did to his. So he drives more than I do and picked up a nail on the sidewall, AT2s were not in stock and the AT3s were just coming out. He got a set for $640 new, installed and out the door in a 265/70/17. The look more agressive and by far are way better than the AT2s which are awesome to begin with. The WPs do look great also but so does a BFG, but I'm not riding on looks!
  18. Jun 21, 2022 at 6:49 AM
    #58
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    Just replaced a set of 255 85 16 Toyo MT with these. So far so good. I only got 25k on the MTs.
  19. Jun 21, 2022 at 7:34 AM
    #59
    baltimorebirds2
    baltimorebirds2 [OP] tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Just got the toyos in! Now I need my trd wheels and once I put the coils, ECGS bushing, and AAL’s in, I can throw those puppies in!
    They look awesome!
  20. Jun 21, 2022 at 7:35 AM
    #60
    baltimorebirds2
    Brooks
    Do you guys think it’s worth paying another 240-280 something for a spare? I’ve heard that it wouldn’t even fit under the truck where the spare tire mounts, so I wonder where I would even put it. I mean would my stock 265/65/17 work in an emergency, if I needed a spare?
    Or I was thinking maybe just buy a small compressor and a plug kit?
