ToYo Open Country Lt265/75R16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AutoDoom, Apr 14, 2021.
  1. Apr 14, 2021 at 2:56 PM
    AutoDoom
    AutoDoom [OP] New Member
    2018 Tocoma Off-road TRD Desert Sand
    Hard top tonneau, rock sliders, 3TPam mount
    Looking at getting these tires. Hopefully someone can let me know if these are a good choice for my 2018 Tacoma Off-Road TRD. Will they rub at all with my truck at stock? From what I have read they should not but wanted to confirm with the group.
  2. Apr 14, 2021 at 4:48 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    They will not rub. Toyo are good tires, you won’t be disappointed.
  3. Apr 14, 2021 at 7:29 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I had them on my Tundra. They lasted from 125k miles to 189k miles before I traded it in for my taco, and they were siped the whole time.
    They helped out when I hit a pothole on the interstate going 90 MPH. Hit hard enough to break my outer tie rod. I think the size and weight of the tires kept that wheel straight. Tires were never able to be balanced after that, but at least I didn't die. :notsure:
    SLeeper512, AutoDoom[OP] and Junkhead like this.
  4. Apr 15, 2021 at 9:32 AM
    AutoDoom
    thanks guys, appreciate it. They look good too.
    Junkhead likes this.
  5. Apr 15, 2021 at 11:02 AM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Have these tires (not the same size) and they look amazing, and will wear the best from what I've seen / researched.
    Don't over inflate them, anything more than 32 should be overkill. You can buy some street chalk and play around with the pressure in the front/back till you find the sweet spot.
    Mine is 30-32 up front, and 28 in the rear.
    Also don't forget to rotate them when you change the oil.
    AutoDoom[OP] likes this.
  6. Apr 15, 2021 at 11:14 AM
    Ol'gray mare
    Ol'gray mare Well-Known Member
    West, Tx
    2017 MGM DCLB TRD OR Geared, locked and tuned, rear disc brakes. 2018 TRD PRO White boss' bone stock
    Build thread coming soon.
    Got 295/75/16 E on my 17 OR and 265/75/16 C on the CFO's 18 PRO the best riding quietest tires we've had on either truck.
    Sand_In_My_Taco likes this.
  7. Apr 15, 2021 at 2:06 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    There are 8 different models of Open Country..
    https://www.toyotires.com/product/open-country
    You'll need the model before we can compare noise, wear, weight, grip, etc etc..
    M/T, R/T, C/T, A/T3, A/T2, H/T, Q/T, WL/T1..
    I've got R/Ts and they are great.
    CreoUCLA likes this.
  8. Apr 15, 2021 at 2:25 PM
    Sand_In_My_Taco
    NOR*CAL
    Good catch!
    I assumed MTs :)
    Ol'gray mare likes this.
  9. Apr 15, 2021 at 7:47 PM
    Ol'gray mare
    West, Tx
    A/T 3's both trucks here.
  10. Apr 16, 2021 at 6:42 AM
    GeronimoCO
    GeronimoCO Active Member
    2016 TRD Off-Road Double Cab
    I got the at/3's and love them so far. They're beefy, solid in the snow and not very noisy at all. The road ride is smooth, they're good-looking and very capable. No rubbing risk at all at that stock size. I would recommend them.
