TOYO OPEN COUNTRY M/T'S 295/70/r17
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJS5870, Nov 3, 2017.
  1. Nov 3, 2017 at 3:43 AM
    AJS5870
    AJS5870 [OP] Well-Known Member
    Andrew
    Raleigh
    2012 TRD Tacoma, DC magnetic gray
    Tint, De-badged. Soon to come. 3" front leveling kit, 265/75/r16 on mickey Thompson classic 3 in black
    20171102_210442.jpg True measurement on these tires is a 34x11.50x17. Got a smoking deal on these guys brand new 500 dollars. was kind of scared about them going to rub too much as I have not don't the Ca mount Chop yet. I was running 285/70/r17 Nitto Terra Grapplers before. No issues what so ever, even flexed, on trails hills inclines anything they never rubbed. I have bilstien 5100's top setting with factory coils (about to change it to OME 888'S and 2nd notch on shock) All Pro leaf pack giving me 3". Got the 295's installed last night and they do not rub driving on pavement. Now offroad, that will be a different story. But being I drive the truck maybe 100 miles a week now, it will be ok for a Bit until I can chop the cab mount.
    SuazoYota, JDawg562, 175908 and 3 others like this.
  2. Nov 3, 2017 at 12:07 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I like!
  3. Nov 5, 2017 at 6:56 PM
    AJS5870
    Andrew
    Raleigh
    totally worth it. did the cab mount chop and it does great offload. no rubbing at all
  4. Nov 5, 2017 at 7:03 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    That's a nice size like a 285/75/17 or 34x11.5 I'd like to go a little bigger but idk if I will towing the camper
  5. Nov 5, 2017 at 7:09 PM
    Pigpen
    Dan
    Northwest Montana
    Why preload an OME coil on 5100s? The shock can up travel over an extra inch. Just put in 1/2" spacers for the extra lift.
    Casper66 likes this.
  6. Nov 6, 2017 at 2:58 AM
    AJS5870
    Andrew
    Raleigh
    285/75/17 is a little taller. Its a 295/70/17. On TOYO's website that tire is a 33.6" tall. the 295 is. the coil is on the very first height setting. which may come off and add the spacer, got lots to do with no time to do it!
  7. Nov 6, 2017 at 6:16 AM
    BrianT23
    BrianT23 Well-Known Member
    CA
    2014 SC/LT/BDGR POOP Tacoma 4x4
    I love my Toyo M/Ts. They wear like a tank even when you have to use them for extended periods of time on pavememt :(:(
  8. Nov 6, 2017 at 8:46 AM
    Pigpen
    Dan
    Northwest Montana
    I really like the proportions of that tire size! And I've always :jerkoff: over those M/Ts. Toyo says my M55s are the same height as they say yours are, but mine are pizza cutters.
    Great looking rig!
  9. Dec 12, 2017 at 8:27 PM
    Eastcoastin
    Eastcoastin Well-Known Member
    Oahu/San Diego
    TRD Sport DCSB 4x4 V6
    Pelfreybilt Baja Designs errythang, 20” Onyx6, S2 Sports, & Squadron Pros King 2.5 Resis w/700 springs/Rear 2.5/12" ALCAN Leaf Springs Total Chaos (Rear Relocation, UCA, spindle gussets, LCA skids) Archive Hangers/shackles Toyo 285/75/17 MTs VTX Rogues InSight RetroFits Leer x100 Camper Custom Car Grills thin lip mesh grill mod w/braptor light mod Tail pipe chop
    still liking these? thinking of upgrading to the same size...
  10. Dec 13, 2017 at 9:44 PM
    DR_SEYMOUR_BUSH
    DR_SEYMOUR_BUSH Well-Known Member
    Tony
    Vancouver, BC
    2008 TRD Sport DCLB BSP
    Bilstein 5100's/OME 885, LR UCA, URD exhaust/intake, Frontrunner rack
    Damn that's a nice tire size! Do you know what your rim width was on these?
  11. Dec 13, 2017 at 9:58 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Any more pics of these? They look absolutely awesome
  12. Dec 16, 2017 at 8:06 PM
    Tacomandan08
    Tacomandan08 Well-Known Member
    Daniel
    2008 Toyota Tacoma trd off road
    6in procomp lift, 17in method wheels,35" bag tires
    If they make a 315/70/17 these might be my next tires. I’m not hearing good things about the BFG’s
  13. Jan 19, 2018 at 10:14 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Those are really nice. They unfortunately don't make a 295 75 16 though do they? :(
