Toyo Open Country M/Ts
Discussion in 'Wheels & Tires' started by jrose350, May 24, 2016.
  1. May 24, 2016 at 7:01 PM
    jrose350
    jrose350 [OP] Member
    2015 Gray TRD Off-Road
    All-weather mats, side steps
    Hi All,
    I wanted to get feedback from anyone that has ran Toyo Open Country M/T tires on their Tacomas. I am considering purchasing a set but want to make sure I'm making the right decision. I love the look and feel of the tires, however 80% of the miles I put on them will be highway miles. Obviously I will maintain consistent tire pressures and rotate them every 5K miles but I wanted to see if anyone could provide any feedback and real world experience as to the actual tread life and performance that I can expect from them?
    Thanks so much
  2. May 24, 2016 at 7:07 PM
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    Go for bfg ko2 instead. I think they ride great on and off road
  3. May 24, 2016 at 8:27 PM
    Pigpen
    Dan
    Northwest Montana
    I don't run the MTs but have friends who do. They're a great tire. That said, they're also loud and don't help your fuel economy any. I would recommend getting something slightly more highway oriented that performs well enough off road - for your stated uses. I went with the Toyo M55 and am very happy on all fronts.
  4. May 24, 2016 at 8:31 PM
    5amtaco93
    5amtaco93 Well-Known Member
    Sam
    South Bend, WA
    '11 base 4x4 5 speed
    I can't remember
    My dad has about 50,000 miles on his toyos. (Just about bald)
    Pros: long tread life (you'd probably get about the same lifespan out of most mt tires out there). Performance is decent. Looks definitely aren't bad either.
    Cons: these tires are HEAVY. Adding heavy tires will take a noticeable toll on your power and gas mileage. They are also noisy. But hey... It's a mud tire.
    I don't think you'd regret buying them.
  5. May 25, 2016 at 12:27 PM
    jrose350
    Thanks for all of the replies and information. Certainly helps in the decision making.
  6. May 25, 2016 at 4:08 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    I just ordered toyo open country H/T
