Toyota 3.4 Liter V6 5VZ-FE Engine Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timmah!, Nov 10, 2020.
  1. Jul 28, 2024 at 4:27 PM
    #41
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Valve covers can be done in a couple hours, someone is BSing you. Fuel injectors are not loud enough to hear inside the cab
    Black97v6MT[QUOTED] likes this.
  2. Jul 28, 2024 at 4:59 PM
    #42
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    5vz valve wear is different from most engines. The clearances get tighter over time and they’ll eventually start burning up the valve. When the engines not ticking at idle you have an issue
  3. Jul 28, 2024 at 5:08 PM
    #43
    Xbowguy
    Xbowguy Well-Known Member
    Jeff
    Pa
    2023 Tacoma 4x4 SR5 double Cab Barcelona Red
    Wow. Extensive job. But I have two words Trade In. lol. But kudos to your rebuild
  4. Jul 29, 2024 at 6:36 AM
    #44
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    thank you, Toyotaholic :)
    would there be any noticeable oil consumption at or nearing that point of tighter clearances? my engine does not consume oil that is noticeable, still full at 5k!
    i believe i still hear normal ticking at the idle (in addition to some abnormal whirring noise coming from underneath that goes away when the clutch is fully pressed to the floor (rebuilt R150F and new OEM clutch parts recently))
  5. Jul 29, 2024 at 2:00 PM
    #45
    TragicBronson
    TragicBronson Well-Known Member
    Eddie
    Pflugerville TX
    2003 Tacoma Dbl cab SR5 4WD
    They call him: Thread from the Dead. :p
    otis24 likes this.
  6. Jul 29, 2024 at 2:07 PM
    #46
    Black97v6MT
    iMA0
    tacoLand USA
    Looks like a promising forum to gather for questions comments concerns regarding this particular engine
    TragicBronson likes this.
